Ana içeriğe geç
2009-2019 Dodge Ram Fog Lights Replacement
Neye ihtiyacın var
  1. 2009-2019 Dodge Ram Fog Lights Replacement, Fog Lights: adım 1, 1 resimden 1.
    • Pull the hood latch that is located beneath the steering column.
  2. 2009-2019 Dodge Ram Fog Lights Replacement: adım 2, 1 resimden 1.
    • Push the lever to the left to unlatch the hood of the truck.
  3. 2009-2019 Dodge Ram Fog Lights Replacement: adım 3, 1 resimden 1.
    • Using the ratchet and 10mm socket, disconnect the negative battery terminal by turning counterclockwise.
    • This is done to make sure you do not get shortages.
  4. 2009-2019 Dodge Ram Fog Lights Replacement: adım 4, 1 resimden 1.
    • Disconnect the lighting harness.
    • Do not remove the bulb since the new fog lamp comes with integrated LED bulbs.
  5. 2009-2019 Dodge Ram Fog Lights Replacement: adım 5, 1 resimden 1.
    • Using the ratchet, extension, and the 10 mm socket unscrew the three 10 mm bolts to let the mounting plate free.
  6. 2009-2019 Dodge Ram Fog Lights Replacement: adım 6, 2 resimden 1. 2009-2019 Dodge Ram Fog Lights Replacement: adım 6, 2 resimden 2.
    • Push the tabs inward and pull the mounting bracket towards you to separate the bracket from the fog lamp.
  7. 2009-2019 Dodge Ram Fog Lights Replacement: adım 7, 1 resimden 1.
    • Grab the new fog lamp and insert the three clips into the three holes of the mounting bracket.
  8. 2009-2019 Dodge Ram Fog Lights Replacement: adım 8, 2 resimden 1. 2009-2019 Dodge Ram Fog Lights Replacement: adım 8, 2 resimden 2.
    • Align the three screw holes on the mounting bracket with the holes on the bumper.
  9. 2009-2019 Dodge Ram Fog Lights Replacement: adım 9, 2 resimden 1. 2009-2019 Dodge Ram Fog Lights Replacement: adım 9, 2 resimden 2.
    • Screw on the three 10 mm bolts in the holes.
    • Tighten the bolts by hand first.
    • Tighten the bolts using the 10 mm socket and ratchet.
  10. 2009-2019 Dodge Ram Fog Lights Replacement: adım 10, 2 resimden 1. 2009-2019 Dodge Ram Fog Lights Replacement: adım 10, 2 resimden 2.
    • Reconnect the lighting harness back up to get a power source.
  11. 2009-2019 Dodge Ram Fog Lights Replacement: adım 11, 2 resimden 1. 2009-2019 Dodge Ram Fog Lights Replacement: adım 11, 2 resimden 2.
    • Make sure the fog lamp is where it is desired and in place.
  12. 2009-2019 Dodge Ram Fog Lights Replacement: adım 12, 1 resimden 1.
    • Reconnect the negative battery terminal.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 21
Son 30 gün: 74
Her zaman: 1,996
