Ana içeriğe geç
2009-2015 Toyota Prius Cabin Air Filter Replacement
Neye ihtiyacın var
  1. 2009-2015 Toyota Prius Cabin Air Filter Replacement, Cabin Air Filter: adım 1, 2 resimden 1. 2009-2015 Toyota Prius Cabin Air Filter Replacement, Cabin Air Filter: adım 1, 2 resimden 2.
    • Press the button to open the glove box.
  2. 2009-2015 Toyota Prius Cabin Air Filter Replacement: adım 2, 3 resimden 1. 2009-2015 Toyota Prius Cabin Air Filter Replacement: adım 2, 3 resimden 2. 2009-2015 Toyota Prius Cabin Air Filter Replacement: adım 2, 3 resimden 3.
    • Pull hook away from glove box that's located on the right side, near the passenger door.
  3. 2009-2015 Toyota Prius Cabin Air Filter Replacement: adım 3, 2 resimden 1. 2009-2015 Toyota Prius Cabin Air Filter Replacement: adım 3, 2 resimden 2.
    • On the opposite side of the glove box, apply pressure and pull it towards you to unlatch the left side.
  4. 2009-2015 Toyota Prius Cabin Air Filter Replacement: adım 4, 3 resimden 1. 2009-2015 Toyota Prius Cabin Air Filter Replacement: adım 4, 3 resimden 2. 2009-2015 Toyota Prius Cabin Air Filter Replacement: adım 4, 3 resimden 3.
    • Hold both sides of the glove box.
    • Push the sides in and lift the glove box up while pulling towards you, to remove the glove box from its compartment.
  5. 2009-2015 Toyota Prius Cabin Air Filter Replacement: adım 5, 3 resimden 1. 2009-2015 Toyota Prius Cabin Air Filter Replacement: adım 5, 3 resimden 2. 2009-2015 Toyota Prius Cabin Air Filter Replacement: adım 5, 3 resimden 3.
    • Push in the tab on the right side of the filter cover while pulling it towards you.
  6. 2009-2015 Toyota Prius Cabin Air Filter Replacement: adım 6, 3 resimden 1. 2009-2015 Toyota Prius Cabin Air Filter Replacement: adım 6, 3 resimden 2. 2009-2015 Toyota Prius Cabin Air Filter Replacement: adım 6, 3 resimden 3.
    • Remove the old air filter by lifting it up slightly and pulling it towards you.
  7. 2009-2015 Toyota Prius Cabin Air Filter Replacement: adım 7, 2 resimden 1. 2009-2015 Toyota Prius Cabin Air Filter Replacement: adım 7, 2 resimden 2.
    • Insert the new cabin air filter by aligning it with the empty space and sliding in.
    • Make sure the arrow on the cabin air filter is pointing in the up direction.
  8. 2009-2015 Toyota Prius Cabin Air Filter Replacement: adım 8, 2 resimden 1. 2009-2015 Toyota Prius Cabin Air Filter Replacement: adım 8, 2 resimden 2.
    • Insert the left side of the cover back into its slot.
    • Push the right side of the cover back into its clip to secure it.
  9. 2009-2015 Toyota Prius Cabin Air Filter Replacement: adım 9, 3 resimden 1. 2009-2015 Toyota Prius Cabin Air Filter Replacement: adım 9, 3 resimden 2. 2009-2015 Toyota Prius Cabin Air Filter Replacement: adım 9, 3 resimden 3.
    • Align the hooks on the glove box with the square holes located at the bottom of the dash.
    • Push the glove box back into the compartment until the sides click into place.
  10. 2009-2015 Toyota Prius Cabin Air Filter Replacement: adım 10, 3 resimden 1. 2009-2015 Toyota Prius Cabin Air Filter Replacement: adım 10, 3 resimden 2. 2009-2015 Toyota Prius Cabin Air Filter Replacement: adım 10, 3 resimden 3.
    • Reinstall the hook on the right side of the glove box by pushing it back over the grey tabs.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Raphael Bret-Mounet
277 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 2-8, Morris Winter 2023 UC Davis, Team 2-8, Morris Winter 2023 üyesi
UCD-MORRIS-W23S2G8
2 Üyeler
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 52
Son 30 gün: 253
Her zaman: 4,064
