Ana içeriğe geç
2009-2015 Toyota Prius Grab Handle Replacement
Neye ihtiyacın var
  1. 2009-2015 Toyota Prius Grab Handle Replacement, Grab Handle: adım 1, 3 resimden 1. 2009-2015 Toyota Prius Grab Handle Replacement, Grab Handle: adım 1, 3 resimden 2. 2009-2015 Toyota Prius Grab Handle Replacement, Grab Handle: adım 1, 3 resimden 3.
    • Locate and lift the handle above the driver's or passenger's seat.
  2. 2009-2015 Toyota Prius Grab Handle Replacement: adım 2, 3 resimden 1. 2009-2015 Toyota Prius Grab Handle Replacement: adım 2, 3 resimden 2. 2009-2015 Toyota Prius Grab Handle Replacement: adım 2, 3 resimden 3.
    • Find tabs for removal of joint cover.
  3. 2009-2015 Toyota Prius Grab Handle Replacement: adım 3, 3 resimden 1. 2009-2015 Toyota Prius Grab Handle Replacement: adım 3, 3 resimden 2. 2009-2015 Toyota Prius Grab Handle Replacement: adım 3, 3 resimden 3.
    • With a spudger, enter the tab and gently apply pressure to disconnect the joint cover from the assembly.
    • Slowly apply pressure away from the frame.
    • Notice that the joint cover is hooked on the inside. Be careful not to damage it.
  4. 2009-2015 Toyota Prius Grab Handle Replacement: adım 4, 2 resimden 1. 2009-2015 Toyota Prius Grab Handle Replacement: adım 4, 2 resimden 2.
    • Repeat the steps to remove the other joint cover.
  5. 2009-2015 Toyota Prius Grab Handle Replacement: adım 5, 2 resimden 1. 2009-2015 Toyota Prius Grab Handle Replacement: adım 5, 2 resimden 2.
    • Remove the handle leaving behind the metal clips.
  6. 2009-2015 Toyota Prius Grab Handle Replacement: adım 6, 3 resimden 1. 2009-2015 Toyota Prius Grab Handle Replacement: adım 6, 3 resimden 2. 2009-2015 Toyota Prius Grab Handle Replacement: adım 6, 3 resimden 3.
    • With a pair of pliers or with your fingers, pinch and pull on the metal clips to remove them.
  7. 2009-2015 Toyota Prius Grab Handle Replacement: adım 7, 3 resimden 1. 2009-2015 Toyota Prius Grab Handle Replacement: adım 7, 3 resimden 2. 2009-2015 Toyota Prius Grab Handle Replacement: adım 7, 3 resimden 3.
    • When replacing the handles, ensure that the metal clips are pointed inward toward the manifold.
    • Insert until it snaps in place.
  8. 2009-2015 Toyota Prius Grab Handle Replacement: adım 8, 3 resimden 1. 2009-2015 Toyota Prius Grab Handle Replacement: adım 8, 3 resimden 2. 2009-2015 Toyota Prius Grab Handle Replacement: adım 8, 3 resimden 3.
    • Insert the joint covers diagonally ensuring the hook is not damaged.
  9. 2009-2015 Toyota Prius Grab Handle Replacement: adım 9, 2 resimden 1. 2009-2015 Toyota Prius Grab Handle Replacement: adım 9, 2 resimden 2.
    • Secure and test the handle.
Bitiş Çizgisi
Erick
169 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 28
Her zaman: 428
