Giriş
Jumpstarting a hybrid can be confusing, especially if the 12V battery isn't under the hood, but it's not impossible! Here's a step-by-step guide on jumpstarting a Toyota Prius, so you can rest assured that you're perfectly capable.
Neye ihtiyacın var
Do not turn the Prius off! Remove the jumper cables while the vehicle is running. Then, turn the second car off, and remove those cables.
Remember, you need to drive the car you just jump started for at least 30 minutes to give the 12V battery time to recharge. Get your battery checked right away and replace it if needed so this doesn't happen again.
That's it! I knew you could do it. Pat yourself on the back and go get your battery checked. You might know how to jump-start your car, but I'm betting you don't want to do it again any time soon.
Bir başkası bu kılavuzu tamamladı.
