Ana içeriğe geç
2009-2014 Hyundai Sonata Cabin Air filter Replacement
  1. 2009-2014 Hyundai Sonata Cabin Air filter Replacement, Cabin Air filter Replacement  for. Hyundai Sonata: adım 1, 1 resimden 1.
    • Go to the passenger side of the car and sit in the passenger seat. Pull the glove box down using the lever.
  2. 2009-2014 Hyundai Sonata Cabin Air filter Replacement: adım 2, 1 resimden 1.
    • On the right side of the love box will be a plastic hydraulic; push the two pieces of plastic of the part sticking out towards each other. This should release the glove box on this side.
  3. 2009-2014 Hyundai Sonata Cabin Air filter Replacement: adım 3, 1 resimden 1.
    • Then on the top left, there is a plastic screw; unscrew it and be mindful that when this happens, the glove box will swing down.
  4. 2009-2014 Hyundai Sonata Cabin Air filter Replacement: adım 4, 1 resimden 1.
    • This is what the screw should look like after you take it out.
  5. 2009-2014 Hyundai Sonata Cabin Air filter Replacement: adım 5, 1 resimden 1.
    • This is what will be behind the glove box.
  6. 2009-2014 Hyundai Sonata Cabin Air filter Replacement: adım 6, 1 resimden 1.
    • On the right side there should be a clamp and push the two ends against each other and pull towards you.
  7. 2009-2014 Hyundai Sonata Cabin Air filter Replacement: adım 7, 1 resimden 1.
    • This is the clamp mentioned in the previous step.
  8. 2009-2014 Hyundai Sonata Cabin Air filter Replacement: adım 8, 1 resimden 1.
    • Then just pull the cover to the right to slide it out. Then you can access the air filter and change it from here.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Brandon Pollaccia
217 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 23
Son 30 gün: 92
Her zaman: 387
