Ana içeriğe geç
2009-2013 Mazda 3 Cabin Air Filter Replacement
Neye ihtiyacın var
  1. 2009-2013 Mazda 3 Cabin Air Filter Replacement, Cabin Air Filter: adım 1, 1 resimden 1.
    • Correctly identify and purchase the cabin air filter for your 2009-2013 Mazda 3 model.
    • If needed, visit your local car parts shop for help buying the cabin air filter.
  2. 2009-2013 Mazda 3 Cabin Air Filter Replacement: adım 2, 3 resimden 1. 2009-2013 Mazda 3 Cabin Air Filter Replacement: adım 2, 3 resimden 2. 2009-2013 Mazda 3 Cabin Air Filter Replacement: adım 2, 3 resimden 3.
    • Remove the panel under the middle console by pulling from the bottom and then from the top.
    • It is on the passenger side of your vehicle.
  3. 2009-2013 Mazda 3 Cabin Air Filter Replacement: adım 3, 2 resimden 1. 2009-2013 Mazda 3 Cabin Air Filter Replacement: adım 3, 2 resimden 2.
    • Remove the black panel under the passenger-side dashboard by unclipping the two tabs,
    • Unclip by pushing on the tabs.
  4. 2009-2013 Mazda 3 Cabin Air Filter Replacement: adım 4, 3 resimden 1. 2009-2013 Mazda 3 Cabin Air Filter Replacement: adım 4, 3 resimden 2. 2009-2013 Mazda 3 Cabin Air Filter Replacement: adım 4, 3 resimden 3.
    • Remove the two 2 mm Phillips screws securing the bottom of the filter housing.
    • Pull the tab at the top of the housing cover to remove it.
    • Handle filter housing parts gently.
  5. 2009-2013 Mazda 3 Cabin Air Filter Replacement: adım 5, 1 resimden 1.
    • Pull out one of the two air filters.
    • The second filter, located on top of first filter, should fall into the same place as you remove the first one.
    • If the second filter doesn't fall, reach it and gently remove it.
  6. 2009-2013 Mazda 3 Cabin Air Filter Replacement: adım 6, 2 resimden 1. 2009-2013 Mazda 3 Cabin Air Filter Replacement: adım 6, 2 resimden 2.
    • Insert the new filters into the slots.
    • The wide side of the air filter goes last.
    • Position the first filter on top.
    • The first filter should fit and stay on top. It might take a few tries.
    • Ensure the second air filter fits tightly underneath the one on top.
  7. 2009-2013 Mazda 3 Cabin Air Filter Replacement: adım 7, 1 resimden 1.
    • Place the housing cover back in position.
    • Tighten the two screws to secure the cover.
  8. 2009-2013 Mazda 3 Cabin Air Filter Replacement: adım 8, 2 resimden 1. 2009-2013 Mazda 3 Cabin Air Filter Replacement: adım 8, 2 resimden 2.
    • Position the black panel under the passenger side dashboard.
    • Clip the two tabs back into place by pushing on them to secure the panel.
    • Align the side panel back under the middle console.
    • Secure the panel by pushing it back into place from the top and the bottom.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Ovi Ahmed
157 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 20
Son 7 gün: 118
Son 30 gün: 487
Her zaman: 1,238
