Ana içeriğe geç
2009 Honda Civic Window Regulator Replacement
Neye ihtiyacın var
  1. 2009 Honda Civic Window Regulator Replacement, Window Regulator: adım 1, 3 resimden 1. 2009 Honda Civic Window Regulator Replacement, Window Regulator: adım 1, 3 resimden 2. 2009 Honda Civic Window Regulator Replacement, Window Regulator: adım 1, 3 resimden 3.
    • Park the vehicle on a level surface and turn off the ignition.
  2. 2009 Honda Civic Window Regulator Replacement: adım 2, 3 resimden 1. 2009 Honda Civic Window Regulator Replacement: adım 2, 3 resimden 2. 2009 Honda Civic Window Regulator Replacement: adım 2, 3 resimden 3.
    • Remove the Phillips screw located behind the door handle.
  3. 2009 Honda Civic Window Regulator Replacement: adım 3, 2 resimden 1. 2009 Honda Civic Window Regulator Replacement: adım 3, 2 resimden 2.
    • Place a prying tool in the small crevice at the centre of the window controller and pry upwards.
  4. 2009 Honda Civic Window Regulator Replacement: adım 4, 2 resimden 1. 2009 Honda Civic Window Regulator Replacement: adım 4, 2 resimden 2.
    • Disconnect the electrical connectors attached to the panel by pressing onto the tab.
  5. 2009 Honda Civic Window Regulator Replacement: adım 5, 3 resimden 1. 2009 Honda Civic Window Regulator Replacement: adım 5, 3 resimden 2. 2009 Honda Civic Window Regulator Replacement: adım 5, 3 resimden 3.
    • Use a prying tool to pry off the door panel.
  6. 2009 Honda Civic Window Regulator Replacement: adım 6, 2 resimden 1. 2009 Honda Civic Window Regulator Replacement: adım 6, 2 resimden 2.
    • Push downwards on the holder and pull the wire towards yourself.
  7. 2009 Honda Civic Window Regulator Replacement: adım 7, 2 resimden 1. 2009 Honda Civic Window Regulator Replacement: adım 7, 2 resimden 2.
    • Use a prying tool to remove the two black plugs on the left-hand side and right-hand side of the plastic liner.
  8. 2009 Honda Civic Window Regulator Replacement: adım 8, 2 resimden 1. 2009 Honda Civic Window Regulator Replacement: adım 8, 2 resimden 2.
    • Remove the connector by pushing onto the tab using a prying tool.
  9. 2009 Honda Civic Window Regulator Replacement: adım 9, 2 resimden 1. 2009 Honda Civic Window Regulator Replacement: adım 9, 2 resimden 2.
    • Gently remove the plastic liner.
  10. 2009 Honda Civic Window Regulator Replacement: adım 10, 2 resimden 1. 2009 Honda Civic Window Regulator Replacement: adım 10, 2 resimden 2.
    • Use a wrench to remove the two bolts located at the left-hand side and right-hand side.
  11. 2009 Honda Civic Window Regulator Replacement: adım 11, 3 resimden 1. 2009 Honda Civic Window Regulator Replacement: adım 11, 3 resimden 2. 2009 Honda Civic Window Regulator Replacement: adım 11, 3 resimden 3.
    • Use the wrench to unscrew the first bolt located at the top of the door in a counterclockwise motion.
    • Use the wrench to unscrew the second bolt located at the bottom of the door in a counterclockwise motion.
  12. 2009 Honda Civic Window Regulator Replacement: adım 12, 2 resimden 1. 2009 Honda Civic Window Regulator Replacement: adım 12, 2 resimden 2.
    • After removing all four bolts, use your hands to remove the window regulator.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Usman Khan
478 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 35
Son 30 gün: 63
Her zaman: 558
