Ana içeriğe geç
2009 Honda Fit Brake Light Bulb Replacement
Neye ihtiyacın var
  1. 2009 Honda Fit Brake Light Bulb Replacement, Brake Light Bulb: adım 1, 1 resimden 1.
    • Open your trunk to access the brake light panel.
  2. 2009 Honda Fit Brake Light Bulb Replacement: adım 2, 3 resimden 1. 2009 Honda Fit Brake Light Bulb Replacement: adım 2, 3 resimden 2. 2009 Honda Fit Brake Light Bulb Replacement: adım 2, 3 resimden 3.
    • Use a trim removal tool or your key to pry the panel and gain access to the brake light.
  3. 2009 Honda Fit Brake Light Bulb Replacement: adım 3, 3 resimden 1. 2009 Honda Fit Brake Light Bulb Replacement: adım 3, 3 resimden 2. 2009 Honda Fit Brake Light Bulb Replacement: adım 3, 3 resimden 3.
    • Rotate the brake light socket clockwise until it unlocks.
    • Pull out the brake light socket.
    • Make sure you are replacing the bottom bulb(brake light) and not the top bulb(tail light).
  4. 2009 Honda Fit Brake Light Bulb Replacement: adım 4, 2 resimden 1. 2009 Honda Fit Brake Light Bulb Replacement: adım 4, 2 resimden 2.
    • Pull out the old bulb from brake light socket and insert new bulb.
    • The old bulb can be identified with its dark burnt look.
    • Wear a nitrile glove or something similar to avoid getting oils from your fingers on the glass bulb. The oils and salt on your hands can reduce the life of the bulb and cause it to burn out more quickly.
  5. 2009 Honda Fit Brake Light Bulb Replacement: adım 5, 2 resimden 1. 2009 Honda Fit Brake Light Bulb Replacement: adım 5, 2 resimden 2.
    • Insert brake light socket with the new bulb into the housing compartment.
    • Similar to the removal, you have to rotate the socket into a locked position.
  6. 2009 Honda Fit Brake Light Bulb Replacement: adım 6, 3 resimden 1. 2009 Honda Fit Brake Light Bulb Replacement: adım 6, 3 resimden 2. 2009 Honda Fit Brake Light Bulb Replacement: adım 6, 3 resimden 3.
    • After reassembly, have someone test the brake light so you can see if it works or not.
    • If no one is available to help, reverse towards a wall and park. Press on the brake and look at your side mirrors to check if they light up.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
mchail
175 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 36
Son 7 gün: 106
Son 30 gün: 146
Her zaman: 685
