Ana içeriğe geç
2009 Subaru Impreza WRX Rear Door Panel Replacement
Neye ihtiyacın var
  1. 2009 Subaru Impreza WRX Rear Door Panel Replacement, Rear Door Panel: adım 1, 1 resimden 1.
    • Pry off the plastic tab inside the rear door handle.
  2. 2009 Subaru Impreza WRX Rear Door Panel Replacement: adım 2, 1 resimden 1.
    • Use the Phillips screwdriver to unscrew the 8x3/4" Phillips screw inside the door handle.
  3. 2009 Subaru Impreza WRX Rear Door Panel Replacement: adım 3, 1 resimden 1.
    • Use a flathead screwdriver to pry up the plastic tab inside the rear door armrest.
  4. 2009 Subaru Impreza WRX Rear Door Panel Replacement: adım 4, 1 resimden 1.
    • Use the Phillips screwdriver to unscrew the 8x3/4" Phillips screw inside the armrest.
  5. 2009 Subaru Impreza WRX Rear Door Panel Replacement: adım 5, 2 resimden 1. 2009 Subaru Impreza WRX Rear Door Panel Replacement: adım 5, 2 resimden 2.
    • Use flathead to pry off the upper panel located at the top of the rear door panel.
  6. 2009 Subaru Impreza WRX Rear Door Panel Replacement: adım 6, 2 resimden 1. 2009 Subaru Impreza WRX Rear Door Panel Replacement: adım 6, 2 resimden 2.
    • Use the flathead screwdriver to pry off and remove the panel over the door handle.
  7. 2009 Subaru Impreza WRX Rear Door Panel Replacement: adım 7, 1 resimden 1.
    • Remove the bundle of wires from the panel by pressing the tabs on the sides of the large white plastic connector.
  8. 2009 Subaru Impreza WRX Rear Door Panel Replacement: adım 8, 1 resimden 1.
    • Use the Phillips screwdriver to unscrew the 8x3/4" screws behind the door handle panel that was just removed.
  9. 2009 Subaru Impreza WRX Rear Door Panel Replacement: adım 9, 1 resimden 1.
    • Use the flathead screwdriver to pry off the door panel, starting from the outside edge of the door.
  10. 2009 Subaru Impreza WRX Rear Door Panel Replacement: adım 10, 1 resimden 1.
    • Use your hands to pull off and remove the door panel from the frame.
  11. 2009 Subaru Impreza WRX Rear Door Panel Replacement: adım 11, 1 resimden 1.
    • Using your hands, remove the two remaining wires connecting the door panel to the frame.
    • The door panel is now completely removed from the frame.
Sonuç
Joseph Coplon
101 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 8-3, Regan Spring 2015 Cal Poly, Team 8-3, Regan Spring 2015 üyesi
CPSU-REGAN-S15S8G3
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 20
Her zaman: 2,453
