Giriş
This guide demonstrates how to replace the stereo unit of the 2009 Subaru Impreza WRX. It can be used to replace a broken unit.
Neye ihtiyacın var
Insert a plastic trim removal tool or pry tool into the seam behind the trim surround, and twist lightly.
Use your hands to slowly pry off the rest of the trim surround.
Locate the white wiring harness behind the stereo housing.
Cut the cords to separate the wires connecting the harness to the car's electrical system.
Note: Be careful not to cut the black wiring harness instead. The black harness is for the CD changer and isn't used in this installation.
Strip each wire in the wiring harness necessary for installation.
Be careful while stripping the wires. They are extremely brittle and tend to rip easily.
Once both the OEM white wiring harness and the black aftermarket wiring harness are stripped, bring the two ends together to start comparing which wires need to be connected.
Connect the wires from the two wiring harnesses.
Crimp Caps, soldering, or wire butt connectors can be used for the connection. Please see related guides for instruction on each method.
Use the table to the left to match up correct wires. Wires not listed are not used in the installation and should either be uncut or taped with electrical tape at the ends.
Locate the aftermarket metal spacer.
Slide it into the mounting bracket.
Press the triangle tabs along each edge to form a solid connection.
Note: There may be a slight amount of movement after the tabs are already pressed. Is is unavoidable and most movement will be removed once the stereo is in place.
Once the cords are reconnected, slide the stereo back into the housing. It will click into place.
Note: Do not force the stereo into place. If it doesn't slid in smoothly, most likely the wiring is in the way and should be adjusted to prevent damage.
Snap the final molding back into place to complete the dash.
5 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
OMG! Instead of cutting off the factory power/speaker harness plug, it's much better to obtain an aftermarket wiring harness. You'll be able to combine that to your new stereo's harness on your workbench or kitchen table instead of working in the cramped space in the car's dash, not to mention being able to quickly and easily reinstall the factory stereo if necessary (e.g., when you want to sell the car). For 2008-2014 (and some 2015) Impreza, WRX, STi, Forester, and Crosstrek models that had the non-navigation OEM stereo, you'll want a Metra 70-7552 or Scosche NN04B. Or if your steering wheel has audio controls that you would like to retain, search for similar aftermarket installation harnesses that include the additional SWC wires.
