Ana içeriğe geç
2010-2017 Suzuki Swift Dome Light Replacement
Neye ihtiyacın var
  1. 2010-2017 Suzuki Swift Dome Light Replacement, remove the dome light fixture: adım 1, 2 resimden 1. 2010-2017 Suzuki Swift Dome Light Replacement, remove the dome light fixture: adım 1, 2 resimden 2.
    • The light fixture is removed entirely in order to replace the bulb more easily. Also, by disconnecting the fixture, the battery does not need to be disconnected.
    • Grab the light fixture at the switch side and pull it loose.
    • Pull the power connector out by pushing on the retaining clip and pushing from below simultaneously.
  2. 2010-2017 Suzuki Swift Dome Light Replacement, replace the light bulb: adım 2, 3 resimden 1. 2010-2017 Suzuki Swift Dome Light Replacement, replace the light bulb: adım 2, 3 resimden 2. 2010-2017 Suzuki Swift Dome Light Replacement, replace the light bulb: adım 2, 3 resimden 3.
    • Grab the bulb and push it out of the fitting.
    • Insert the new bulb by slotting it in on the flexible end and pushing it in. Make sure the other end is slotted into the fitting.
    • If you are using a LED light, make sure you turn the lights towards the lens after installation.
Sonuç
knipwim
14.906 İtibar
42 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 45
Son 30 gün: 167
Her zaman: 749
