Ana içeriğe geç
2010-2017 Suzuki Swift Engine Air Filter Replacement
Neye ihtiyacın var
  1. 2010-2017 Suzuki Swift Engine Air Filter Replacement, locate the filter: adım 1, 3 resimden 1. 2010-2017 Suzuki Swift Engine Air Filter Replacement, locate the filter: adım 1, 3 resimden 2. 2010-2017 Suzuki Swift Engine Air Filter Replacement, locate the filter: adım 1, 3 resimden 3.
    • The filter housing is located behind the air intake.
    • Pull both clasps holding the filter housing to the air intake.
    • Push the housing back to see the filter.
  2. 2010-2017 Suzuki Swift Engine Air Filter Replacement, remove old filter: adım 2, 2 resimden 1. 2010-2017 Suzuki Swift Engine Air Filter Replacement, remove old filter: adım 2, 2 resimden 2.
    • Slide the old filter up and out.
    • Remember the only square corner of the filter is in the left bottom side.
    • Clean the immediate area of the filter housing, to make sure no dirt ends up in the engine.
  3. 2010-2017 Suzuki Swift Engine Air Filter Replacement, add new filter: adım 3, 1 resimden 1.
    • With the square corner at the correct position, slide the new filter in.
    • Make sure the filter fits up with the backside of the air intake on all sides.
  4. 2010-2017 Suzuki Swift Engine Air Filter Replacement, close the filter housing: adım 4, 2 resimden 1. 2010-2017 Suzuki Swift Engine Air Filter Replacement, close the filter housing: adım 4, 2 resimden 2.
    • Underneath the air filter, 2 holes have to line up with plugs on the filter housing.
    • Once the underside is connected correctly, a small plastic protrustion has to line up with a corresponding guide on the air intake.
    • Clip back the 2 clips, and you are done.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
knipwim
8.685 İtibar
31 adet Kılavuz yazıldı
Bir Yorum
Thanks a lot
burakkurhan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 34
Son 30 gün: 127
Her zaman: 6,757
