Ana içeriğe geç
2010-2017 Suzuki Swift Tail Light Bulb Replacement
Neye ihtiyacın var
  1. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, loosen the tail light: adım 1, 3 resimden 1. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, loosen the tail light: adım 1, 3 resimden 2. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, loosen the tail light: adım 1, 3 resimden 3.
    • Unscrew the two visible bolts.
    • After unscrewing the bolts, the other side of the light is still fastened by two clickable plugs.
    • Using the panel removal tool, pry behind each corner and unclick each plug.
  2. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, access backside of the light: adım 2, 1 resimden 1.
    • Remove the light from the frame and place it on the tailgate.
    • You might need to remove some of the cabling from cable guides.
    • You can also better see the plugs that held the light in place.
  3. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, remove the fitting: adım 3, 1 resimden 1.
    • Unscrew the fitting about 45 degrees and lift it from the casing.
  4. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, replace the bulb: adım 4, 2 resimden 1. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, replace the bulb: adım 4, 2 resimden 2.
    • Remove the bulb by turning it about 45 degrees.
    • And do the reverse with the new bulb, push and turn.
    • The bulb has 2 guide pins assuring a correct install.
    • The fitting has 2 corresponding receivers.
  5. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, insert fitting: adım 5, 1 resimden 1.
    • Insert the fitting by matching up the fitting guides with their openings on the casing and turn it 45 degrees clockwise.
  6. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, put the light back: adım 6, 1 resimden 1.
    • Tuck back any cables you loosened, and place the light back on the car frame.
    • Make sure the replaced light actually works.
    • Push the light plugs back in.
    • Put the 2 screws back in.
    • You are done.
Bitiş Çizgisi
5 farklı kişi bu kılavuzu tamamladı.
knipwim
8.527 İtibar
30 adet Kılavuz yazıldı
Bir Yorum
Two bulbs not working
SATYANARAYANA VASAMSETTY - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 14
Son 7 gün: 85
Son 30 gün: 433
Her zaman: 35,084
