Ana içeriğe geç
2010-2015 Hyundai Elantra Spark Plug Replacement
Neye ihtiyacın var
  1. 2010-2015 Hyundai Elantra Spark Plug Replacement, Spark Plug Replacement: adım 1, 1 resimden 1.
    • Make sure the car is off and cooled down entirely by allowing at least the car not to be in use for two hours or more.
  2. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 2, 3 resimden 1. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 2, 3 resimden 2. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 2, 3 resimden 3.
    • Open the hood by pulling upwards on the lever found by the lower left side of the driver seat.
    • Lift the hood with your hands by opening the latch that holds the hood down.
    • Prop up the hood stick to hold the hood open.
  3. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 3, 3 resimden 1. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 3, 3 resimden 2. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 3, 3 resimden 3.
    • Loosen and remove the nut next to the battery terminal using the 10mm socket attached to the wrench.
  4. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 4, 3 resimden 1. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 4, 3 resimden 2. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 4, 3 resimden 3.
    • Move the power supply cable aside carefully and wedge it between the battery.
  5. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 5, 2 resimden 1. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 5, 2 resimden 2.
    • Remove the engine cover by placing both hands on each side and placing it aside from our work station.
  6. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 6, 3 resimden 1. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 6, 3 resimden 2. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 6, 3 resimden 3.
    • Unfasten the lock pins from the electrical connectors and place them aside by the battery.
  7. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 7, 3 resimden 1. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 7, 3 resimden 2. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 7, 3 resimden 3.
    • Unscrew the four screws from the ignition coils using an 8mm socket attached to a wrench.
  8. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 8, 3 resimden 1. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 8, 3 resimden 2. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 8, 3 resimden 3.
    • Remove all four ignition coils and keep them in order as you remove them outside of our work station.
  9. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 9, 3 resimden 1. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 9, 3 resimden 2. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 9, 3 resimden 3.
    • Loosen and remove spark plugs with a ⅝ long socket with an eight-inch socket extension and wrench.
    • Use a magnetic pickup tool to remove the spark plugs.
  10. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 10, 3 resimden 1. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 10, 3 resimden 2. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 10, 3 resimden 3.
    • Insert the new spark plugs gently to avoid damaging the spark plug using the magnetic pickup tool.
  11. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 11, 3 resimden 1. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 11, 3 resimden 2. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 11, 3 resimden 3.
    • Use the 5/8 socket with an 8-inch extension attached to a wrench to tighten the spark plug, without breaking the spark plug.
  12. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 12, 3 resimden 1. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 12, 3 resimden 2. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 12, 3 resimden 3.
    • Insert ignition coils into their designated places.
  13. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 13, 3 resimden 1. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 13, 3 resimden 2. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 13, 3 resimden 3.
    • Insert and tighten screws for the ignition coils using the 10 mm socket attached to the wrench.
  14. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 14, 3 resimden 1. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 14, 3 resimden 2. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 14, 3 resimden 3.
    • Connect all four electrical connectors and lock them back into place.
  15. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 15, 3 resimden 1. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 15, 3 resimden 2. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 15, 3 resimden 3.
    • Place the engine cover back into its designated spot.
  16. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 16, 3 resimden 1. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 16, 3 resimden 2. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 16, 3 resimden 3.
    • Reconnect the battery by moving the power supply cable back into its terminal.
    • Tighten the nut back alongside the terminal using the 10mm socket attached to a wrench.
    • Close the positive terminal battery cover and ensure it is properly closed.
  17. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 17, 3 resimden 1. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 17, 3 resimden 2. 2010-2015 Hyundai Elantra Spark Plug Replacement: adım 17, 3 resimden 3.
    • Place the hood stick back into its designated spot and gently close the hood.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
Robert
305 İtibar
1 Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 2-1, Briggs Fall 2023 CSU Los Angeles, Team 2-1, Briggs Fall 2023 üyesi
CSULA-BRIGGS-F23S2G1
6 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 77
Son 30 gün: 326
Her zaman: 1,965
