Giriş
Here is an easy step by step solution on how to replace a 2010-2014 Dodge Ram 1500 headlight. If one or both of your headlights no longer turns on and you’ve determined that the bulbs have burnt out on your headlights, follow this guide for instructions on how to replace them. Following this will save you money and a trip to the mechanic shop.
Neye ihtiyacın var
Öne Çıkan Belge
Pull the hood latch under the driver's steering wheel.
Positioning yourself at the hood of the truck in front of the logo, put two fingers under the hood to find the latch.
Push the latch to the left, hold, and lift the hood.
Use the support rod to keep the hood propped open.
Bir başkası bu kılavuzu tamamladı.
