Ana içeriğe geç
2010-2014 Ford Mustang Air Filter Replacement
  1. 2010-2014 Ford Mustang Air Filter Replacement, Air Filter: adım 1, 2 resimden 1. 2010-2014 Ford Mustang Air Filter Replacement, Air Filter: adım 1, 2 resimden 2.
    • Make sure the vehicle is off before proceeding. Working under the cars hood can lead to burns if the car is still hot. Be careful!
    • Open the hood by pulling on the lever by the driver's feet.
    • Push upward on the latch under the center of the hood to unlock it.
  2. 2010-2014 Ford Mustang Air Filter Replacement: adım 2, 1 resimden 1.
    • Locate the Air Box
  3. 2010-2014 Ford Mustang Air Filter Replacement: adım 3, 3 resimden 1. 2010-2014 Ford Mustang Air Filter Replacement: adım 3, 3 resimden 2. 2010-2014 Ford Mustang Air Filter Replacement: adım 3, 3 resimden 3.
    • Locate the two latches that keep the air box closed.
    • Push on the latch to open the air box as shown in the picture, and repeat on the second latch.
    • Pull up on the top part of the air box and push it to the front of the car to open.
  4. 2010-2014 Ford Mustang Air Filter Replacement: adım 4, 2 resimden 1. 2010-2014 Ford Mustang Air Filter Replacement: adım 4, 2 resimden 2.
    • Make note of the orientation of the air filter before removing it.
    • Lift the filter straight up from the triangle corner and remove it.
  5. 2010-2014 Ford Mustang Air Filter Replacement: adım 5, 2 resimden 1. 2010-2014 Ford Mustang Air Filter Replacement: adım 5, 2 resimden 2.
    • Inspect for debris and dirt.
    • The first filter is dirty but does not need to be cleaned or replaced yet.
    • The second filter is dirty and does need to be cleaned or replaced
    • Do not discard the filter because it may be covered under a warranty.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Christopher Pell
251 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-45, Forte Fall 2012 Cal Poly, Team 15-45, Forte Fall 2012 üyesi
CPSU-FORTE-F12S15G45
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 36
Her zaman: 4,785
