Giriş
Replace the tail light bulbs in a 2010 GMC Sierra. Tail lights are for telling other drivers that a vehicle is stopping. Ensuring proper tail light operation is important, and so is doing this process correctly. Make sure to have a replacement tail light bulb, some latex gloves, a 10mm wrench, and a Philips head #2 screwdriver before beginning.
Neye ihtiyacın var
Open the hood of the truck.
Using the 10mm wrench, loosen and remove the 1-3/4" bolt securing the cable.
Pull the cable from the battery.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Is there a way to get these things not to get moisture inside the backup bulb area?
