Ana içeriğe geç
2010 Jeep Liberty Headlight Bulb Replacement
Neye ihtiyacın var
  1. 2010 Jeep Liberty Headlight Bulb Replacement, Headlight Bulb: adım 1, 1 resimden 1.
    • Pop the hood of your vehicle by pulling the lever near the bottom of the driver's side door.
    • Slide your hands under the unlatched hood to find the second lever. Push this lever to the right and lift the hood.
    • Be sure to use the hood prop to keep the hood from falling while you're underneath it.
  2. 2010 Jeep Liberty Headlight Bulb Replacement: adım 2, 3 resimden 1. 2010 Jeep Liberty Headlight Bulb Replacement: adım 2, 3 resimden 2. 2010 Jeep Liberty Headlight Bulb Replacement: adım 2, 3 resimden 3.
    • Identify the bulb socket, located behind the headlight.
    • Rotate the base of the bulb counter-clockwise to remove it from the socket.
    • Remove the bulb from the green base by pulling the two apart.
  3. 2010 Jeep Liberty Headlight Bulb Replacement: adım 3, 3 resimden 1. 2010 Jeep Liberty Headlight Bulb Replacement: adım 3, 3 resimden 2. 2010 Jeep Liberty Headlight Bulb Replacement: adım 3, 3 resimden 3.
    • Insert the new bulb into the green base.
    • Be sure not to touch the glass with your fingers. If you do, wipe the bulb down with a soft cloth and some rubbing alcohol. Oils left behind from your fingers can shorten the life of the bulb.
    • Rotate clockwise to lock the bulb assembly into the socket.
  4. 2010 Jeep Liberty Headlight Bulb Replacement: adım 4, 1 resimden 1.
    • Turn on headlights to ensure the new bulb is working properly.
    • You will want to check that your headlights are aligned on both sides. Adjust as needed.
Sonuç
Congratulations! You have a shiny new headlight.
8 farklı kişi bu kılavuzu tamamladı.
Ryan Griffin
245 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 77
Her zaman: 9,462
