Ana içeriğe geç
2010 Toyota Corolla Headlight Replacement
Neye ihtiyacın var
  1. 2010 Toyota Corolla Headlight Replacement, Headlight Bulb: adım 1, 3 resimden 1. 2010 Toyota Corolla Headlight Replacement, Headlight Bulb: adım 1, 3 resimden 2. 2010 Toyota Corolla Headlight Replacement, Headlight Bulb: adım 1, 3 resimden 3.
    • Find the handle to open the Bonnet. It will be located at the bottom left-hand side of the driver's seat.
    • Pull the handle towards yourself and you will see the bonnet pop up a small bit.
  2. 2010 Toyota Corolla Headlight Replacement: adım 2, 3 resimden 1. 2010 Toyota Corolla Headlight Replacement: adım 2, 3 resimden 2. 2010 Toyota Corolla Headlight Replacement: adım 2, 3 resimden 3.
    • Move the handle to the left in order to release the hood completely.
    • Locate the black stick and insert it in the bonnet hole.
  3. 2010 Toyota Corolla Headlight Replacement: adım 3, 3 resimden 1. 2010 Toyota Corolla Headlight Replacement: adım 3, 3 resimden 2. 2010 Toyota Corolla Headlight Replacement: adım 3, 3 resimden 3.
    • On the left, upper side of the hood, you can locate the bulb
    • Twist it halfway counter-clockwise and pull it out.
  4. 2010 Toyota Corolla Headlight Replacement: adım 4, 3 resimden 1. 2010 Toyota Corolla Headlight Replacement: adım 4, 3 resimden 2. 2010 Toyota Corolla Headlight Replacement: adım 4, 3 resimden 3.
    • Push the hook down to detach the bulb from the wire.
  5. 2010 Toyota Corolla Headlight Replacement: adım 5, 3 resimden 1. 2010 Toyota Corolla Headlight Replacement: adım 5, 3 resimden 2. 2010 Toyota Corolla Headlight Replacement: adım 5, 3 resimden 3.
    • Replace it with a new bulb and turn it clockwise to have it fixed permanently.
    • If the bulb is not turned clockwise, the bulb will come off and become loose again.
  6. 2010 Toyota Corolla Headlight Replacement: adım 6, 3 resimden 1. 2010 Toyota Corolla Headlight Replacement: adım 6, 3 resimden 2. 2010 Toyota Corolla Headlight Replacement: adım 6, 3 resimden 3.
    • Turn on the lights to make sure both headlights are working :)
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Shahbaz Khan
193 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 17
Son 30 gün: 92
Her zaman: 2,576
