Giriş
Are you having troubles with your headlights and needs to be replaced?
Whether it might be the cause of extreme weather, a burnt-out bulb, or a blown fuse.
Follow these 6 easy steps to have them replaced and running again.
Please note: This guide will only work if the problem is with the bulb and not the wiring. If the problem is with the wiring, please consult your mechanic.
(A good indication of a burnt-out bulb is to see if one headlight is working and the other is not. If both are not working, It could mean there is something wrong with the wiring and not the bulbs)
Neye ihtiyacın var
Find the handle to open the Bonnet. It will be located at the bottom left-hand side of the driver's seat.
Pull the handle towards yourself and you will see the bonnet pop up a small bit.
3 farklı kişi bu kılavuzu tamamladı.
