Ana içeriğe geç
2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement
  1. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement, Back-Up Light and Brake Light: adım 1, 3 resimden 1. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement, Back-Up Light and Brake Light: adım 1, 3 resimden 2. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement, Back-Up Light and Brake Light: adım 1, 3 resimden 3.
    • Make sure the car is off before you start your replacement. However, You don't have to disconnect the car battery.
    • Open the trunk first.
    • Using Phillips #2 screwdriver, remove the two 10 mm screws from the back & tail light.
  2. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: adım 2, 3 resimden 1. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: adım 2, 3 resimden 2. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: adım 2, 3 resimden 3.
    • Using both hands, carefully pull the brake & tail light off.
  3. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: adım 3, 1 resimden 1.
    • Here is the tail light assembly.
    • The left one is for the brake light.
    • The right one is for the back-up light.
  4. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: adım 4, 3 resimden 1. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: adım 4, 3 resimden 2. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: adım 4, 3 resimden 3.
    • Twist and turn the backup light to the right. And then pull it out.
    • Make sure not to touch the surface of the light bulb because it will break the light bulb easily.
  5. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: adım 5, 3 resimden 1. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: adım 5, 3 resimden 2. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: adım 5, 3 resimden 3.
    • Twist and turn the brake light to the right and pull it out.
    • Make sure not to touch the surface of the light bulb because it will break the bulb easily.
  6. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: adım 6, 3 resimden 1. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: adım 6, 3 resimden 2. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: adım 6, 3 resimden 3.
    • Replace the light bulbs.
    • Check that the light bulbs work first before replacing 10 mm screws.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Adrian Ng
196 İtibar
1 Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 42
Son 30 gün: 192
Her zaman: 2,685
