Giriş
This guide will help you safely and correctly replace the alternator from a 2011 - 2017 Volkswagen Jetta.
Neye ihtiyacın var
Use the 10 mm socket wrench to do this step.
Loosen the nut on the connector by turning it counter-clockwise.
The belt loosening bolt is on the left, below the alternator.
Push the belt off of the alternator.
Do not completely remove belt from engine.
Locate the 4 screws holding the alternator in place two on the top and two on the bottom.
Remove cap and electrical connector located on the right side of the alternator before removing the alternator.
Photo was taken after the alternator was removed to provide a better picture.
4 farklı kişi bu kılavuzu tamamladı.
2 Yorum
What engine is this guide for?
