Ana içeriğe geç
2011-2014 Dodge Challenger Engine Air Filter Replacement
Neye ihtiyacın var
  1. 2011-2014 Dodge Challenger Engine Air Filter Replacement, Engine Air Filter: adım 1, 1 resimden 1.
    • Pop The Engine Hood Open
    • Reminder- Hood Latch Release is Under the Steering Wheel
  2. 2011-2014 Dodge Challenger Engine Air Filter Replacement: adım 2, 1 resimden 1.
    • Locate The Air Intake In Engine Bay
    • Hint- Should be on the Lower Right-Hand Side
  3. 2011-2014 Dodge Challenger Engine Air Filter Replacement: adım 3, 2 resimden 1. 2011-2014 Dodge Challenger Engine Air Filter Replacement: adım 3, 2 resimden 2.
    • Using A Flat Head Screwdriver Remove All 3 Screws Holding In the Air Intake Cover
    • Reminder All 3 screws are the same size 12mm no need to keep track of where they go
  4. 2011-2014 Dodge Challenger Engine Air Filter Replacement: adım 4, 1 resimden 1.
    • Using the FlatHead screwdriver Loosen the clamp holding in the Air Intake
    • Tip- Do not fully remove the clamp Just Loosen it
  5. 2011-2014 Dodge Challenger Engine Air Filter Replacement: adım 5, 1 resimden 1.
    • Remove AIr Intake Lid
    • Tip- Place Intake Lid Above the Intake to not Loosen Hose Going to the Intake
  6. 2011-2014 Dodge Challenger Engine Air Filter Replacement: adım 6, 2 resimden 1. 2011-2014 Dodge Challenger Engine Air Filter Replacement: adım 6, 2 resimden 2.
    • Locate and Remove The Air Filter
  7. 2011-2014 Dodge Challenger Engine Air Filter Replacement: adım 7, 1 resimden 1.
    • Insert New Air Filter
  8. 2011-2014 Dodge Challenger Engine Air Filter Replacement: adım 8, 1 resimden 1.
    • Reapply the Air Intake Lid
  9. 2011-2014 Dodge Challenger Engine Air Filter Replacement: adım 9, 1 resimden 1.
    • Reapply all 3 Screws For the Intake Lid
    • Tighten the Clamp on the Hose Going to the Intake
Sonuç
Now you Have Completely Replaced Your car's Engine Air Filter.
Bir başkası bu kılavuzu tamamladı.
jhr1091
169 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 21
Son 30 gün: 66
Her zaman: 247
