Ana içeriğe geç
2011-2013 Scion tC Car Battery Replacement
Neye ihtiyacın var
  1. 2011-2013 Scion tC Car Battery Replacement, Car Battery: adım 1, 1 resimden 1.
    • Begin by opening the hood of the car and locating the battery on the front of the driver side in the engine compartment
  2. 2011-2013 Scion tC Car Battery Replacement: adım 2, 1 resimden 1.
    • Using a socket wrench, loosen the 2 (5/16 inch) nuts on the top of the battery support bracket
    • Remove the bracket by lifting up
  3. 2011-2013 Scion tC Car Battery Replacement: adım 3, 1 resimden 1.
    • After removing the bracket, locate the supporting rod behind the battery
    • The rod is hooked on a hole in the metal behind the battery. Unhook the rod and remove it
  4. 2011-2013 Scion tC Car Battery Replacement: adım 4, 2 resimden 1. 2011-2013 Scion tC Car Battery Replacement: adım 4, 2 resimden 2.
    • Start with the negative terminal of the battery
    • Loosen the nut on the negative terminal with a 10mm socket wrench
    • Remove the wire by slightly twisting and pulling up
  5. 2011-2013 Scion tC Car Battery Replacement: adım 5, 2 resimden 1. 2011-2013 Scion tC Car Battery Replacement: adım 5, 2 resimden 2.
    • Remove the cap from the positive terminal of the battery
    • Using a 10mm socket wrench, loosen the nut on the positive terminal
    • Remove the wire from the positive terminal by slightly twisting and pulling up
    • Remove the battery by lifting it out of the engine compartment
Sonuç
Bir başkası bu kılavuzu tamamladı.
Travis Michael
140 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 8-2, Regan Spring 2015 Cal Poly, Team 8-2, Regan Spring 2015 üyesi
CPSU-REGAN-S15S8G2
5 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 37
Her zaman: 11,025
