Giriş
Oil changes are an important part of maintaining any vehicle and to ensure your Scion’s longevity. Conventional oil changes should be done every 3000-5000 miles. If using synthetic oil, you should change it closer to every 5000-7000 miles. With a couple tools and the right supplies, changing your oil on a 2011-2013 Scion tC is not difficult.
It is important to be cautious when changing your oil or anytime you are under a vehicle. Make sure your car is secure on jack stands or ramps before getting underneath. Also let the engine cool off before changing your oil so that the oil is not too hot.
After purchasing the supplies and gathering the tools, follow this guide to replace the oil and oil filter in your 2011-2013 Scion tC.
Note: Always check with the manufacturer or the manual provided with your vehicle to determine the proper oil weight to use.
Warning: Conducting maintenance or repair on your vehicle can be dangerous. Exercise extreme caution when following this guide.
Neye ihtiyacın var
Open the spare tire compartment in the trunk of the vehicle by pulling up on the black tab.
Replace the oil filter with a new one. Once reinserted into the filter housing, relube the o-ring with some fresh oil and reinstall on the filter housing. To reassemble your device, follow these instructions in reverse order.
5 farklı kişi bu kılavuzu tamamladı.
