Ana içeriğe geç
2011-2013 Scion tC Radio Head Unit Replacement
Neye ihtiyacın var
  1. 2011-2013 Scion tC Radio Head Unit Replacement, Radio Head Unit: adım 1, 2 resimden 1. 2011-2013 Scion tC Radio Head Unit Replacement, Radio Head Unit: adım 1, 2 resimden 2.
    • Remove the dashboard panel around the radio head by pulling on the bottom of the unit.
  2. 2011-2013 Scion tC Radio Head Unit Replacement: adım 2, 2 resimden 1. 2011-2013 Scion tC Radio Head Unit Replacement: adım 2, 2 resimden 2.
    • Remove the wire header connected to the panel by pressing inward on the tabs.
  3. 2011-2013 Scion tC Radio Head Unit Replacement: adım 3, 1 resimden 1.
    • Remove the four #2 12mm screws securing the head unit in the housing
  4. 2011-2013 Scion tC Radio Head Unit Replacement: adım 4, 2 resimden 1. 2011-2013 Scion tC Radio Head Unit Replacement: adım 4, 2 resimden 2.
    • Remove each bundle of wires that is connected to the back of the head unit.
  5. 2011-2013 Scion tC Radio Head Unit Replacement: adım 5, 2 resimden 1. 2011-2013 Scion tC Radio Head Unit Replacement: adım 5, 2 resimden 2.
    • Locate the metal brackets on the side of the head unit.
    • Use a Philips head screwdriver, remove the three #2 25mm screws from both support brackets on the side of the head unit
  6. 2011-2013 Scion tC Radio Head Unit Replacement: adım 6, 1 resimden 1.
    • Screw the support brackets to the new radio head unit
    • Note that the brackets are unique to the car. They will not come with your new head unit.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Dylan Smith
143 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 8-2, Regan Spring 2015 Cal Poly, Team 8-2, Regan Spring 2015 üyesi
CPSU-REGAN-S15S8G2
5 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 28
Her zaman: 7,753
