Ana içeriğe geç
2011 Ford Fiesta Headlight Replacement
Neye ihtiyacın var
  1. 2011 Ford Fiesta Headlight Replacement, Indicator Bulb: adım 1, 1 resimden 1.
    • Park the car where you have room to work.
    • Check that the hand brake is on and the engine is off.
    • Wait for the car to cool down before opening the hood. The hot air from the engine may damage the eyes and cause burns.
    • Ensure that the car has rested for at least 30 minutes.
  2. 2011 Ford Fiesta Headlight Replacement: adım 2, 3 resimden 1. 2011 Ford Fiesta Headlight Replacement: adım 2, 3 resimden 2. 2011 Ford Fiesta Headlight Replacement: adım 2, 3 resimden 3.
    • Pull the hood release under the driver's dashboard towards you.
  3. 2011 Ford Fiesta Headlight Replacement: adım 3, 3 resimden 1. 2011 Ford Fiesta Headlight Replacement: adım 3, 3 resimden 2. 2011 Ford Fiesta Headlight Replacement: adım 3, 3 resimden 3.
    • Make sure there is space to insert fingers. If not, repeat step 2.
    • Push the yellow hood release to the left to open the hood.
  4. 2011 Ford Fiesta Headlight Replacement: adım 4, 2 resimden 1. 2011 Ford Fiesta Headlight Replacement: adım 4, 2 resimden 2.
    • Lift the hood with one hand and place the strut upright in the correct position.
    • Place strut in the hole to the left of the hood.
  5. 2011 Ford Fiesta Headlight Replacement: adım 5, 3 resimden 1. 2011 Ford Fiesta Headlight Replacement: adım 5, 3 resimden 2. 2011 Ford Fiesta Headlight Replacement: adım 5, 3 resimden 3.
    • Use a flathead screwdriver to loosen the lower retained screw.
    • Collect the screws and store them somewhere safe.
  6. 2011 Ford Fiesta Headlight Replacement: adım 6, 2 resimden 1. 2011 Ford Fiesta Headlight Replacement: adım 6, 2 resimden 2.
    • Remove the upper retained screw.
    • Store the screw in a safe place.
  7. 2011 Ford Fiesta Headlight Replacement: adım 7, 3 resimden 1. 2011 Ford Fiesta Headlight Replacement: adım 7, 3 resimden 2. 2011 Ford Fiesta Headlight Replacement: adım 7, 3 resimden 3.
    • Carefully remove the headlight.
    • The headlight is attached to three electrical connectors.
    • Gently pull up and towards your body.
    • Set the headlight to the side.
  8. 2011 Ford Fiesta Headlight Replacement: adım 8, 3 resimden 1. 2011 Ford Fiesta Headlight Replacement: adım 8, 3 resimden 2. 2011 Ford Fiesta Headlight Replacement: adım 8, 3 resimden 3.
    • Press both ends of the bulb container to remove the electrical connector from the bulb container.
  9. 2011 Ford Fiesta Headlight Replacement: adım 9, 3 resimden 1. 2011 Ford Fiesta Headlight Replacement: adım 9, 3 resimden 2. 2011 Ford Fiesta Headlight Replacement: adım 9, 3 resimden 3.
    • Pull out the bulb from the headlight.
    • Press both ends of the electrical connector to separate from the bulb container.
  10. 2011 Ford Fiesta Headlight Replacement: adım 10, 1 resimden 1.
    • Make sure you do not hold the glass surface with your bare hands. The bulb may malfunction from the sweat in your hands.
    • Hold the black part of the bulb.
    • The bulb might break, so be sure to wear gloves and protective glasses.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Phillip Kataswa
208 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 40
Son 30 gün: 281
Her zaman: 7,123
