Ana içeriğe geç
2011 Ford Focus Air Conditioning Refrigerant Replacement
Neye ihtiyacın var
  1. 2011 Ford Focus Air Conditioning  Refrigerant Replacement, Air Conditioning Refrigerant: adım 1, 3 resimden 1. 2011 Ford Focus Air Conditioning  Refrigerant Replacement, Air Conditioning Refrigerant: adım 1, 3 resimden 2. 2011 Ford Focus Air Conditioning  Refrigerant Replacement, Air Conditioning Refrigerant: adım 1, 3 resimden 3.
    • Turn the car on and the A/C to the maximum.
  2. 2011 Ford Focus Air Conditioning  Refrigerant Replacement: adım 2, 1 resimden 1.
    • Open your car's hood.
  3. 2011 Ford Focus Air Conditioning  Refrigerant Replacement: adım 3, 2 resimden 1. 2011 Ford Focus Air Conditioning  Refrigerant Replacement: adım 3, 2 resimden 2.
    • Locate the low-pressure charging port.
  4. 2011 Ford Focus Air Conditioning  Refrigerant Replacement: adım 4, 1 resimden 1.
    • Remove the cap by turning it counter-clockwise.
  5. 2011 Ford Focus Air Conditioning  Refrigerant Replacement: adım 5, 2 resimden 1. 2011 Ford Focus Air Conditioning  Refrigerant Replacement: adım 5, 2 resimden 2.
    • Connect the nozzle and hold the canister at a 3 o'clock angle.
    • Warning: Keep an eye on the PSI level. It should stay between 30 and 50, as going beyond 50 psi could cause the car's compressor to become damaged.
    • Lock and remove the canister if it is around 40 to prevent it from going to 50 psi.
    • Finally, start up the car. If the air conditioning is cooler, you'll know that it works!
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 69
Son 30 gün: 252
Her zaman: 4,405
