Ana içeriğe geç
2011 Honda Pilot Overhead Lightbulb and Switch Replacement
Neye ihtiyacın var
  1. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement, Overhead Lightbulb and Switch: adım 1, 3 resimden 1. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement, Overhead Lightbulb and Switch: adım 1, 3 resimden 2. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement, Overhead Lightbulb and Switch: adım 1, 3 resimden 3.
    • Use a plastic pry tool to detach the light cover.
    • Be careful not to pry too hard, otherwise you risk breaking the cover.
  2. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: adım 2, 3 resimden 1. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: adım 2, 3 resimden 2. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: adım 2, 3 resimden 3.
    • Use the pry tool to the light and attach the new one inside of the clamps that hold the bulb.
    • Repeat the same process for the left side bulb.
  3. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: adım 3, 2 resimden 1. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: adım 3, 2 resimden 2.
    • Remove the screws inside of the unit using a Phillips #00 screwdriver.
  4. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: adım 4, 3 resimden 1. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: adım 4, 3 resimden 2. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: adım 4, 3 resimden 3.
    • Open the sunglasses case.
    • Use a Phillips #00 screwdriver to remove the screws.
    • Keep track of the screws. The front ones are silver, while the black ones inside the sunglasses case are black.
  5. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: adım 5, 1 resimden 1.
    • After the screws come undone, this is what the unit should look like.
  6. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: adım 6, 3 resimden 1. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: adım 6, 3 resimden 2. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: adım 6, 3 resimden 3.
    • Press down on the four cable clamps to detach them.
    • Do not use the wires to pull them out. You may risk damaging the cables connecting to the unit.
  7. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: adım 7, 1 resimden 1.
    • After detaching all cables, the unit should look like this and come right off.
  8. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: adım 8, 2 resimden 1. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: adım 8, 2 resimden 2.
    • Insert a plastic pry tool inside this little slot. Once you do, flick up to release this middle part from the unit.
  9. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: adım 9, 3 resimden 1. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: adım 9, 3 resimden 2. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: adım 9, 3 resimden 3.
    • Insert a prying tool into the button switch. Then push out to flick out the button.
    • Once the button has fallen out, insert the new switches by sliding them back where the old ones were.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nicholas Sisneros
169 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 40
Her zaman: 98
