Ana içeriğe geç
2011 Mazda 3 Car Speaker Replacement
Neye ihtiyacın var
  1. 2011 Mazda 3 Car Speaker Replacement, 2011 Mazda 3 Car Speaker: adım 1, 3 resimden 1. 2011 Mazda 3 Car Speaker Replacement, 2011 Mazda 3 Car Speaker: adım 1, 3 resimden 2. 2011 Mazda 3 Car Speaker Replacement, 2011 Mazda 3 Car Speaker: adım 1, 3 resimden 3.
    • Pry the door handle cover upwards using a flathead screwdriver.
    • Remove the cover to expose the screw.
  2. 2011 Mazda 3 Car Speaker Replacement: adım 2, 2 resimden 1. 2011 Mazda 3 Car Speaker Replacement: adım 2, 2 resimden 2.
    • Pull the door handle towards you.
    • Insert a small flathead screwdriver between the lock and the plate.
    • Pry the plate off by applying leverage away from the lock, exposing the second screw.
  3. 2011 Mazda 3 Car Speaker Replacement: adım 3, 2 resimden 1. 2011 Mazda 3 Car Speaker Replacement: adım 3, 2 resimden 2.
    • Remove both screws with a Phillips #1 screwdriver.
    • The screws are 12mm Phillip's head. Part number (9986-50-516S).
  4. 2011 Mazda 3 Car Speaker Replacement: adım 4, 1 resimden 1.
    • Pry the door cover away from the frame using a heavy-duty spudger.
    • The door cover will not be removed entirely in this step.
    • Prying the door off takes substantial force; moving around the door's perimeter will help unhook the clips that line the panel.
  5. 2011 Mazda 3 Car Speaker Replacement: adım 5, 2 resimden 1. 2011 Mazda 3 Car Speaker Replacement: adım 5, 2 resimden 2.
    • Push the switch panel out from the inside of the door cover.
    • Ensure the car is off before proceeding.
    • Remove the wires connected to the panel by pressing the clips and pulling them outward.
    • Remove the door cover.
  6. 2011 Mazda 3 Car Speaker Replacement: adım 6, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the four screws that secure the door speaker.
    • The screws are 10mm Phillip's head. Part number (9984-50-616).
  7. 2011 Mazda 3 Car Speaker Replacement: adım 7, 1 resimden 1.
    • Remove the wires connecting the speaker by pressing the clip and pulling it outward.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 16
Son 30 gün: 80
Her zaman: 2,447
