Ana içeriğe geç
2011 Scion Tc Blower Motor Replacement
Neye ihtiyacın var
  1. 2011 Scion Tc Blower Motor Replacement, Blower Motor: adım 1, 1 resimden 1.
    • Locate your blower motor. Your blower motor should be below the glovebox.
  2. 2011 Scion Tc Blower Motor Replacement: adım 2, 1 resimden 1.
    • Remove the three 2 mm screws that secure the blower motor.
  3. 2011 Scion Tc Blower Motor Replacement: adım 3, 1 resimden 1.
    • Remove the two 1 mm Phillips #0 screws that secure the blower motor wiring harness.
  4. 2011 Scion Tc Blower Motor Replacement: adım 4, 2 resimden 1. 2011 Scion Tc Blower Motor Replacement: adım 4, 2 resimden 2.
    • Disconnect the sensor that is connect to the blower motor.
    • The sensor should have a click and carefully remove it upwards.
  5. 2011 Scion Tc Blower Motor Replacement: adım 5, 2 resimden 1. 2011 Scion Tc Blower Motor Replacement: adım 5, 2 resimden 2.
    • Put the new blower motor in place, and secure it with the three 2 mm Phillips #0 screws.
  6. 2011 Scion Tc Blower Motor Replacement: adım 6, 1 resimden 1.
    • Tighten the two 1 mm screws to the wiring harness.
  7. 2011 Scion Tc Blower Motor Replacement: adım 7, 1 resimden 1.
    • Congratulations, you have successfully replaced your blower motor!
    • Once all the screws are tightened, just make sure to turn on your air to see if your blower motor works!
Sonuç
Jose Ruvalcaba
145 İtibar
1 Kılavuz yazıldı
Bir Yorum
Is the blower motor inside of the car under the glovebox? Do I need to replace the glovebox to get to the blower motor?
Christopher Sean Harris - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 42
Son 30 gün: 55
Her zaman: 1,493
