Ana içeriğe geç
2011 Toyota Sienna Headlight Bulb Replacement
Neye ihtiyacın var
  1. 2011 Toyota Sienna Headlight Bulb Replacement, Headlight Bulb: adım 1, 3 resimden 1. 2011 Toyota Sienna Headlight Bulb Replacement, Headlight Bulb: adım 1, 3 resimden 2. 2011 Toyota Sienna Headlight Bulb Replacement, Headlight Bulb: adım 1, 3 resimden 3.
    • Pull out the hood release latch located towards the lower left of the steering wheel.
  2. 2011 Toyota Sienna Headlight Bulb Replacement: adım 2, 3 resimden 1. 2011 Toyota Sienna Headlight Bulb Replacement: adım 2, 3 resimden 2. 2011 Toyota Sienna Headlight Bulb Replacement: adım 2, 3 resimden 3.
    • Hold up the hood safety latch with one hand and lift the hood of the car with the other hand.
    • Pull the hood all the way up to ensure it engages and stays up.
  3. 2011 Toyota Sienna Headlight Bulb Replacement: adım 3, 2 resimden 1. 2011 Toyota Sienna Headlight Bulb Replacement: adım 3, 2 resimden 2.
    • Locate the headlight bulb housings on each side if the hood.
    • It's advisable to replace both headlights even if only one is burned out. The other light is likely to go out soon, and replacing both now can help avoid additional repairs.
  4. 2011 Toyota Sienna Headlight Bulb Replacement: adım 4, 3 resimden 1. 2011 Toyota Sienna Headlight Bulb Replacement: adım 4, 3 resimden 2. 2011 Toyota Sienna Headlight Bulb Replacement: adım 4, 3 resimden 3.
    • Push the button on the electrical connector until you hear a click.
    • Pull down to remove the electrical connector.
  5. 2011 Toyota Sienna Headlight Bulb Replacement: adım 5, 2 resimden 1. 2011 Toyota Sienna Headlight Bulb Replacement: adım 5, 2 resimden 2.
    • Twist the bulb counter clockwise.
  6. 2011 Toyota Sienna Headlight Bulb Replacement: adım 6, 1 resimden 1.
    • Pull out the bulb.
    • Insert your new light bulb.
    • If you are not wearing gloves, avoid touching the glass part of the bulb since the oils from your skin will damage the bulb.
Sonuç
Madeleine Falcon
183 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 31
Her zaman: 269
