Ana içeriğe geç
2012 - 2018 Hyundai Santa Fe Sport Brake Light Replacement
Neye ihtiyacın var
  1. 2012 - 2018 Hyundai Santa Fe Sport Brake Light Replacement, Brake Light: adım 1, 3 resimden 1. 2012 - 2018 Hyundai Santa Fe Sport Brake Light Replacement, Brake Light: adım 1, 3 resimden 2. 2012 - 2018 Hyundai Santa Fe Sport Brake Light Replacement, Brake Light: adım 1, 3 resimden 3.
    • Open the trunk.
    • Remove the black plastic cover located on the inner side taillight by using a #2 flat head screwdriver.
    • Make sure to pry it off gently to avoid cracking the plastic cover.
  2. 2012 - 2018 Hyundai Santa Fe Sport Brake Light Replacement: adım 2, 3 resimden 1. 2012 - 2018 Hyundai Santa Fe Sport Brake Light Replacement: adım 2, 3 resimden 2. 2012 - 2018 Hyundai Santa Fe Sport Brake Light Replacement: adım 2, 3 resimden 3.
    • Remove the two 12 mm Phillips # 2 screws holding the taillight in place.
  3. 2012 - 2018 Hyundai Santa Fe Sport Brake Light Replacement: adım 3, 1 resimden 1.
    • Slide out the headlights placing one hand on the outer side and the other hand gripped onto the back of the taillight, pulling straight out.
    • For easier removal, press down with force on the outer side of the headlight.
  4. 2012 - 2018 Hyundai Santa Fe Sport Brake Light Replacement: adım 4, 3 resimden 1. 2012 - 2018 Hyundai Santa Fe Sport Brake Light Replacement: adım 4, 3 resimden 2. 2012 - 2018 Hyundai Santa Fe Sport Brake Light Replacement: adım 4, 3 resimden 3.
    • Turn the grey brake light socket with the multi-colored wires connected to it counterclockwise.
  5. 2012 - 2018 Hyundai Santa Fe Sport Brake Light Replacement: adım 5, 2 resimden 1. 2012 - 2018 Hyundai Santa Fe Sport Brake Light Replacement: adım 5, 2 resimden 2.
    • Pull out the light bulb from the grey bulb socket by pushing downwards while turning counterclockwise.
  6. 2012 - 2018 Hyundai Santa Fe Sport Brake Light Replacement: adım 6, 2 resimden 1. 2012 - 2018 Hyundai Santa Fe Sport Brake Light Replacement: adım 6, 2 resimden 2.
    • Take the new replacement bulb and insert it into the light socket while pushing down onto the bulb, turning clockwise and securing the bulb in place.
  7. 2012 - 2018 Hyundai Santa Fe Sport Brake Light Replacement: adım 7, 2 resimden 1. 2012 - 2018 Hyundai Santa Fe Sport Brake Light Replacement: adım 7, 2 resimden 2.
    • Slide the light socket back into the circular compartment, making sure the bulb is facing inwards.
    • After inserted, turn it clockwise to lock the bulb back into place.
  8. 2012 - 2018 Hyundai Santa Fe Sport Brake Light Replacement: adım 8, 3 resimden 1. 2012 - 2018 Hyundai Santa Fe Sport Brake Light Replacement: adım 8, 3 resimden 2. 2012 - 2018 Hyundai Santa Fe Sport Brake Light Replacement: adım 8, 3 resimden 3.
    • Slide the taillight back into the starting position.
    • Align the taillight with a circular piece on the outer side of the car.
    • Use moderate force while sliding the taillight, making sure screw holes are visible.
    • Make sure the grey circular piece on the side is aligned with the taillight to avoid damaging the taillight.
  9. 2012 - 2018 Hyundai Santa Fe Sport Brake Light Replacement: adım 9, 2 resimden 1. 2012 - 2018 Hyundai Santa Fe Sport Brake Light Replacement: adım 9, 2 resimden 2.
    • Take the two 12 mm Phillip #2 screws and place them back into the two visible holes.
  10. 2012 - 2018 Hyundai Santa Fe Sport Brake Light Replacement: adım 10, 3 resimden 1. 2012 - 2018 Hyundai Santa Fe Sport Brake Light Replacement: adım 10, 3 resimden 2. 2012 - 2018 Hyundai Santa Fe Sport Brake Light Replacement: adım 10, 3 resimden 3.
    • Replace the plastic cover by pushing down on all of the corners.
    • Once the plastic piece is fixed onto the car, you can then close the trunk.
    • The plastic piece is secure when all the sides are lined up with the car and taillight.
    • Avoid applying a significant amount of force to prevent cracks in the plastic.
Sonuç
You have now completed the guide, to replace the brake bulb on your 2012 - 2018 Hyundai Santa Fe Sport.
4 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Very good examples and explanation! Wonder if there is a post for the inner tailgate lights as well?
Kenneth - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 108
Son 30 gün: 547
Her zaman: 10,111
