Ana içeriğe geç
2012-2018 Nissan Versa Note Headlight Bulb Replacement
  1. 2012-2018 Nissan Versa Note Headlight Bulb Replacement, Headlight Bulb: adım 1, 2 resimden 1. 2012-2018 Nissan Versa Note Headlight Bulb Replacement, Headlight Bulb: adım 1, 2 resimden 2.
    • Pull the hood lever.
  2. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: adım 2, 1 resimden 1.
    • Push the lever underneath the hood to the left.
    • The lever is located in the center underneath the hood.
  3. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: adım 3, 1 resimden 1.
    • Pull up the hood.
  4. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: adım 4, 1 resimden 1.
    • Insert the support rod into the slot.
    • The stent is located to the right of the hood.
    • The slot is located in the underside of the hood to the right.
  5. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: adım 5, 2 resimden 1. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: adım 5, 2 resimden 2.
    • Pull out the connector from the bulb.
    • Depending on the make of your vehicle, you may have push the tab on the connector that reads "push" before pulling out the connector.
  6. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: adım 6, 1 resimden 1.
    • Twist the plastic ring out from the bulb.
  7. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: adım 7, 2 resimden 1. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: adım 7, 2 resimden 2.
    • Pull out the old bulb.
    • High pressure halogen gas is sealed inside the halogen bulb. The bulb may break if the glass envelope is scratched or the bulb is dropped.
    • When handling the bulb, do not touch the glass envelope.
  8. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: adım 8, 2 resimden 1. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: adım 8, 2 resimden 2.
    • Insert the replacement bulb.
  9. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: adım 9, 1 resimden 1.
    • Twist the plastic ring back onto the bulb.
  10. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: adım 10, 2 resimden 1. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: adım 10, 2 resimden 2.
    • Insert the connector into the bulb.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 45
Son 30 gün: 227
Her zaman: 8,388
