Ana içeriğe geç
2012-2017 Toyota Corolla Rear Seat Hinge Replacement
Neye ihtiyacın var
  1. 2012-2017 Toyota Corolla Rear Seat Hinge Replacement, Rear seat hinge: adım 1, 3 resimden 1. 2012-2017 Toyota Corolla Rear Seat Hinge Replacement, Rear seat hinge: adım 1, 3 resimden 2. 2012-2017 Toyota Corolla Rear Seat Hinge Replacement, Rear seat hinge: adım 1, 3 resimden 3.
    • Unlock the latch on top of the rear seats and pull both seats down.
    • Lift the trunk's carpeting up to reveal the circular hooks attached to the seats' carpeting. Unhook the seats' carpeting from the circular hooks in the trunk, revealing the hinges.
  2. 2012-2017 Toyota Corolla Rear Seat Hinge Replacement: adım 2, 3 resimden 1. 2012-2017 Toyota Corolla Rear Seat Hinge Replacement: adım 2, 3 resimden 2. 2012-2017 Toyota Corolla Rear Seat Hinge Replacement: adım 2, 3 resimden 3.
    • Use a 12mm wrench/ratchet to loosen and remove the bolt on the hinge. Repeat this for both sides of the backseat(s).
    • Keep the bolts and washers unless broken.
  3. 2012-2017 Toyota Corolla Rear Seat Hinge Replacement: adım 3, 3 resimden 1. 2012-2017 Toyota Corolla Rear Seat Hinge Replacement: adım 3, 3 resimden 2. 2012-2017 Toyota Corolla Rear Seat Hinge Replacement: adım 3, 3 resimden 3.
    • To remove the seat(s), apply downward pressure on the seat back next to the hooks holding the latch and seat together. Slide the hinge toward the trunk to move it out of the way. Repeat for both hinges.
  4. 2012-2017 Toyota Corolla Rear Seat Hinge Replacement: adım 4, 1 resimden 1.
    • Remove the seat(s) from the car and place them on a towel, tarp, sheet, or blanket to avoid scratching the leather on the asphalt.
  5. 2012-2017 Toyota Corolla Rear Seat Hinge Replacement: adım 5, 3 resimden 1. 2012-2017 Toyota Corolla Rear Seat Hinge Replacement: adım 5, 3 resimden 2. 2012-2017 Toyota Corolla Rear Seat Hinge Replacement: adım 5, 3 resimden 3.
    • Use a 12mm wrench/ratchet to remove the remaining bolt(s) on the hinges.
    • Remove the hinge.
  6. 2012-2017 Toyota Corolla Rear Seat Hinge Replacement: adım 6, 2 resimden 1. 2012-2017 Toyota Corolla Rear Seat Hinge Replacement: adım 6, 2 resimden 2.
    • Bolt down the new hinge to the frame of the car using a new or existing bolt and the 12mm wrench/ratchet.
    • Be sure to mount the hinge in the same orientation as when it was removed.
    • Apply a generous amount of torque so that the bolt is firmly tight, but do not over-tighten.
    • (Bolts can be purchased from Toyota or various resellers)
  7. 2012-2017 Toyota Corolla Rear Seat Hinge Replacement: adım 7, 3 resimden 1. 2012-2017 Toyota Corolla Rear Seat Hinge Replacement: adım 7, 3 resimden 2. 2012-2017 Toyota Corolla Rear Seat Hinge Replacement: adım 7, 3 resimden 3.
    • Insert the seat(s) back into car, making sure that the middle seat belt is not trapped on the backside of the seat(s).
    • Slide the hinges back over the seat(s), making sure to line up the bolt hole on the seat(s) with the bolt hole on the hinges. Press the seat down to hook the hinges back into the seat.
  8. 2012-2017 Toyota Corolla Rear Seat Hinge Replacement: adım 8, 2 resimden 1. 2012-2017 Toyota Corolla Rear Seat Hinge Replacement: adım 8, 2 resimden 2.
    • Bolt down the hinges to the seats using the 12mm wrench/ratchet until they are firmly snug.
    • Do not over tighten the bolts, as they are easily stripped.
  9. 2012-2017 Toyota Corolla Rear Seat Hinge Replacement: adım 9, 2 resimden 1. 2012-2017 Toyota Corolla Rear Seat Hinge Replacement: adım 9, 2 resimden 2.
    • Reverse the removal of the carpeting, making sure to reattach the circular hooks to the seat's carpeting.
    • Move the seats to an upright position and push them back until the latch clicks and seats cannot be moved forward.
Sonuç
Congratulations, you’re finished!
Bir başkası bu kılavuzu tamamladı.
Ben Calvert
169 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 22
Son 30 gün: 98
Her zaman: 7,182
