Ana içeriğe geç
2012-2016 Honda CR-V Oil and Oil Filter Replacement
Neye ihtiyacın var
  1. 2012-2016 Honda CR-V Oil and Oil Filter Replacement, Oil and Oil Filter: adım 1, 2 resimden 1. 2012-2016 Honda CR-V Oil and Oil Filter Replacement, Oil and Oil Filter: adım 1, 2 resimden 2.
    • Open the hood by pulling the hood latch.
    • Oil may be hot if the engine has not cooled.
    • Keep vehicle in park and off unless otherwise noted.
    • Chock both back wheels with blocks of wood to prevent car from rolling.
  2. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: adım 2, 2 resimden 1. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: adım 2, 2 resimden 2.
    • Let the vehicle cool for 15 minutes if needed. Clean the area around the oil cap. Remove the oil cap.
  3. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: adım 3, 3 resimden 1. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: adım 3, 3 resimden 2. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: adım 3, 3 resimden 3.
    • Locate the dipstick and check oil level.
  4. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: adım 4, 1 resimden 1.
    • Place the drain pain under the chassis and align with the drain bolt.
  5. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: adım 5, 1 resimden 1.
    • Locate the drain bolt.
  6. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: adım 6, 3 resimden 1. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: adım 6, 3 resimden 2. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: adım 6, 3 resimden 3.
    • Remove the drain bolt with a 17mm socket wrench, and completely drain the oil.
  7. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: adım 7, 1 resimden 1.
    • Remove the oil filter with a 45mm oil filter socket.
  8. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: adım 8, 3 resimden 1. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: adım 8, 3 resimden 2. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: adım 8, 3 resimden 3.
    • Replace the drain bolt with a new drain bolt gasket (crush washer); Honda Washer, Drain Plug (14MM) 94109-14000. Use the 17mm socket wrench to tighten.
  9. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: adım 9, 2 resimden 1. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: adım 9, 2 resimden 2.
    • Install the new filter in place of the old filter. Hand tighten instead of using the oil filter wrench.
  10. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: adım 10, 2 resimden 1. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: adım 10, 2 resimden 2.
    • Place the medium funnel and add new 0W-20 full synthetic engine oil. Add 4.2 quarts of oil.
  11. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: adım 11, 1 resimden 1.
    • Replace the oil cap.
  12. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: adım 12, 1 resimden 1.
    • Start the vehicle, and check for any leaks around the oil filter and oil drain plug.
    • Stop the vehicle and let the engine rest for 5 minutes.
  13. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: adım 13, 3 resimden 1. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: adım 13, 3 resimden 2. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: adım 13, 3 resimden 3.
    • Use the dip stick to double check oil level and add more if needed.
    • Make sure the oil level is in between the low and high marks on the dip stick. Replace the dip stick and close the hood.
    • Reset the oil life in the maintenance section of the vehicle computer.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 28
Son 7 gün: 157
Son 30 gün: 716
Her zaman: 20,463
