Ana içeriğe geç
2012-2015 Honda Civic Spark Plugs Replacement
Neye ihtiyacın var
  1. 2012-2015 Honda Civic Spark Plugs Replacement, Spark Plugs: adım 1, 3 resimden 1. 2012-2015 Honda Civic Spark Plugs Replacement, Spark Plugs: adım 1, 3 resimden 2. 2012-2015 Honda Civic Spark Plugs Replacement, Spark Plugs: adım 1, 3 resimden 3.
    • Use a flathead screwdriver to remove the two screws holding the engine cover in place.
    • Remove the engine cover.
  2. 2012-2015 Honda Civic Spark Plugs Replacement: adım 2, 2 resimden 1. 2012-2015 Honda Civic Spark Plugs Replacement: adım 2, 2 resimden 2.
    • Locate the four spark plug connectors.
    • Insert a screwdriver into the space in the wire connector and lift the lid.
  3. 2012-2015 Honda Civic Spark Plugs Replacement: adım 3, 3 resimden 1. 2012-2015 Honda Civic Spark Plugs Replacement: adım 3, 3 resimden 2. 2012-2015 Honda Civic Spark Plugs Replacement: adım 3, 3 resimden 3.
    • Locate the bolt securing the ignition coil.
    • Use a wrench with a 10 mm socket to remove the bolt securing the ignition coil.
    • Once the bolt is removed, pull out the ignition coil.
  4. 2012-2015 Honda Civic Spark Plugs Replacement: adım 4, 3 resimden 1. 2012-2015 Honda Civic Spark Plugs Replacement: adım 4, 3 resimden 2. 2012-2015 Honda Civic Spark Plugs Replacement: adım 4, 3 resimden 3.
    • Locate the old spark plug.
    • Use a wrench with a spark plug socket (with a rubber grommet) to unscrew the spark plug.
    • Once the spark plug is unscrewed, pull out the wrench along with the spark plug.
  5. 2012-2015 Honda Civic Spark Plugs Replacement: adım 5, 2 resimden 1. 2012-2015 Honda Civic Spark Plugs Replacement: adım 5, 2 resimden 2.
    • Ensure that the new spark plug is dry.
    • Use a gap measuring tool to ensure that the spark plug gap is appropriate.
    • It is optional to lightly coat the threads with anti-seize to help remove them in the future.
    • Do not get anti-seize on the electrodes (the gap at the top of the threads).
  6. 2012-2015 Honda Civic Spark Plugs Replacement: adım 6, 2 resimden 1. 2012-2015 Honda Civic Spark Plugs Replacement: adım 6, 2 resimden 2.
    • Attach the new spark plug to the spark plug socket, and finger tighten the new spark plug.
    • Use the wrench to tighten the spark plug to 45 degrees.
    • Do not overtighten the spark plug.
    • Re-insert the ignition coil.
  7. 2012-2015 Honda Civic Spark Plugs Replacement: adım 7, 2 resimden 1. 2012-2015 Honda Civic Spark Plugs Replacement: adım 7, 2 resimden 2.
    • Use the wrench with the 10 mm socket to tighten the bolt that fastens the ignition coil.
    • Re-connect the wire connecter to the ignition coil.
Sonuç
Repeat steps for the remaining 3 spark plugs. Reattach the engine cover with the flathead screwdriver.
2 farklı kişi bu kılavuzu tamamladı.
Anthony
175 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 14
Son 7 gün: 85
Son 30 gün: 421
Her zaman: 3,279
