Ana içeriğe geç
2012 BMW 3 Series Windshield Wiper Replacement
Neye ihtiyacın var
  1. 2012 BMW 3 Series Windshield Wiper Replacement, Windshield Wiper: adım 1, 2 resimden 1. 2012 BMW 3 Series Windshield Wiper Replacement, Windshield Wiper: adım 1, 2 resimden 2.
    • To begin, open the hood and make sure the broken wiper's body is completely positioned on the hood.
    • This is done to prevent scratches from developing throughout the repair process.
  2. 2012 BMW 3 Series Windshield Wiper Replacement: adım 2, 2 resimden 1. 2012 BMW 3 Series Windshield Wiper Replacement: adım 2, 2 resimden 2.
    • Use your fingers to pop the cover off that holds the wiper in place.
  3. 2012 BMW 3 Series Windshield Wiper Replacement: adım 3, 2 resimden 1. 2012 BMW 3 Series Windshield Wiper Replacement: adım 3, 2 resimden 2.
    • Use a back and forth motion to carefully remove the wiper blade from the wiper arm. and then pull it out.
  4. 2012 BMW 3 Series Windshield Wiper Replacement: adım 4, 2 resimden 1. 2012 BMW 3 Series Windshield Wiper Replacement: adım 4, 2 resimden 2.
    • Install the replacement wiper so that the slightly bent angle side faces the vehicle.
  5. 2012 BMW 3 Series Windshield Wiper Replacement: adım 5, 2 resimden 1. 2012 BMW 3 Series Windshield Wiper Replacement: adım 5, 2 resimden 2.
    • Check that the screw is aligned with the hole.
    • With a little pressure, slowly slide the new wiper into place.
  6. 2012 BMW 3 Series Windshield Wiper Replacement: adım 6, 2 resimden 1. 2012 BMW 3 Series Windshield Wiper Replacement: adım 6, 2 resimden 2.
    • Once it is positioned correctly, lock the cover to keep the blade in place.
    • If you hear a click, you will know you have succeeded.
    • Lower the windshield wiper carefully onto the windshield.
  7. 2012 BMW 3 Series Windshield Wiper Replacement: adım 7, 1 resimden 1.
    • Finally, test your wiper blades by spraying water or windshield wiper cleaner over your windshield and turning on the wipers.
    • You are done if they are wiping properly. If they appear to be loose, make sure they are securely attached before driving again.
Sonuç
Hafsa Yusuf
145 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 32
Her zaman: 878
