Ana içeriğe geç
2012 Ford Fusion Brake Light Replacement
Neye ihtiyacın var
    1. 2012 Ford Fusion Brake Light Replacement, Brake Light: adım 1, 2 resimden 1. 2012 Ford Fusion Brake Light Replacement, Brake Light: adım 1, 2 resimden 2.
      • Locate the button that opens the trunk
      FixBot'a Sor
      Yorum Ekle
    2. 2012 Ford Fusion Brake Light Replacement: adım 2, 2 resimden 1. 2012 Ford Fusion Brake Light Replacement: adım 2, 2 resimden 2.
      • Locate plastic fasteners and remove with door panel remove tool/flathead by prying them off
      FixBot'a Sor
      Yorum Ekle
    3. 2012 Ford Fusion Brake Light Replacement: adım 3, 2 resimden 1. 2012 Ford Fusion Brake Light Replacement: adım 3, 2 resimden 2.
      • Pull tab and remove trunk cover
      FixBot'a Sor
      Yorum Ekle
    4. 2012 Ford Fusion Brake Light Replacement: adım 4, 2 resimden 1. 2012 Ford Fusion Brake Light Replacement: adım 4, 2 resimden 2.
      • On the inside of the trunk remove the side panel to locate the brake light bulb
      FixBot'a Sor
      Yorum Ekle
    5. 2012 Ford Fusion Brake Light Replacement: adım 5, 1 resimden 1.
      • Pull the Brown housing that holds the brake light
      FixBot'a Sor
      Yorum Ekle
    6. 2012 Ford Fusion Brake Light Replacement: adım 6, 2 resimden 1. 2012 Ford Fusion Brake Light Replacement: adım 6, 2 resimden 2.
      • Remove brake light from housing by pulling it out gently and replace with new bulb
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your taillight bulb, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 16
Son 30 gün: 49
Her zaman: 6,986
