Ana içeriğe geç
2012 Ford Fusion Headlight Replacement
Neye ihtiyacın var
  1. 2012 Ford Fusion Headlight Replacement, Headlight: adım 1, 1 resimden 1.
    • Locate the hood latch and pull it to open
  2. 2012 Ford Fusion Headlight Replacement: adım 2, 3 resimden 1. 2012 Ford Fusion Headlight Replacement: adım 2, 3 resimden 2. 2012 Ford Fusion Headlight Replacement: adım 2, 3 resimden 3.
    • The front hood will open and be caught by a saftey latch. Run fingers under the hood and push the latch to the left to open the hood completely
  3. 2012 Ford Fusion Headlight Replacement: adım 3, 2 resimden 1. 2012 Ford Fusion Headlight Replacement: adım 3, 2 resimden 2.
    • Hold up the hood with the hood support rod
  4. 2012 Ford Fusion Headlight Replacement: adım 4, 2 resimden 1. 2012 Ford Fusion Headlight Replacement: adım 4, 2 resimden 2.
    • Remove negative terminal from the battery using a 10mm socket. Remove the bolt that is holding the negative terminal and pull terminal off the battery.
  5. 2012 Ford Fusion Headlight Replacement: adım 5, 2 resimden 1. 2012 Ford Fusion Headlight Replacement: adım 5, 2 resimden 2.
    • Locate the headlight bulb in the front of the car under the hood and twist off the cap covering the headlight bulb
  6. 2012 Ford Fusion Headlight Replacement: adım 6, 2 resimden 1. 2012 Ford Fusion Headlight Replacement: adım 6, 2 resimden 2.
    • twist the housing to the light bulb and pull it out
  7. 2012 Ford Fusion Headlight Replacement: adım 7, 2 resimden 1. 2012 Ford Fusion Headlight Replacement: adım 7, 2 resimden 2.
    • unclip the light bulb from the housing latch and replace light bulb
Sonuç
To reassemble your headlight, follow these instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
5Kılavuz Yorumları
What about the left side?
destroyer2040 - Yanıt
So this was completely useless. You only showed the one semi easy to reach bulb whereas the rest look like the front of the car needs to be disassembled to reach. Why even post this useless junk?
Joe - Yanıt
I agree with both previous comments. your efforts are INCOMPLETE.
What about the left side(PASSENGER  SIDE THAT IS)
You only showed the one semi easy to reach(DRIVER’S SIDE, THAT IS)
Al Moghtader - Yanıt
Yea this guide is incomplete and not helpful.
John Fisher - Yanıt
what years do the head lite assy match with on 2012 ford fusion sle
gordon r bissell - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 19
Son 30 gün: 99
Her zaman: 14,494
