Ana içeriğe geç
2012 Nissan Sentra Rear Taillight Replacement
Neye ihtiyacın var
  1. 2012 Nissan Sentra Rear Taillight Replacement, Rear Taillight: adım 1, 3 resimden 1. 2012 Nissan Sentra Rear Taillight Replacement, Rear Taillight: adım 1, 3 resimden 2. 2012 Nissan Sentra Rear Taillight Replacement, Rear Taillight: adım 1, 3 resimden 3.
    • Open the trunk.
    • Locate the plastic large bolt behind the taillight.
    • This bolt holds the grey cover in place.
    • Remove the bolt with a flat head screw driver or wrench.
  2. 2012 Nissan Sentra Rear Taillight Replacement: adım 2, 3 resimden 1. 2012 Nissan Sentra Rear Taillight Replacement: adım 2, 3 resimden 2. 2012 Nissan Sentra Rear Taillight Replacement: adım 2, 3 resimden 3.
    • Peel back the grey cover to expose the back casing of the taillight.
  3. 2012 Nissan Sentra Rear Taillight Replacement: adım 3, 3 resimden 1. 2012 Nissan Sentra Rear Taillight Replacement: adım 3, 3 resimden 2. 2012 Nissan Sentra Rear Taillight Replacement: adım 3, 3 resimden 3.
    • Use a small wrench to loosen the two nuts securing the bolts.
    • Locate the group of wires in the center that connect to the bulbs.
  4. 2012 Nissan Sentra Rear Taillight Replacement: adım 4, 3 resimden 1. 2012 Nissan Sentra Rear Taillight Replacement: adım 4, 3 resimden 2. 2012 Nissan Sentra Rear Taillight Replacement: adım 4, 3 resimden 3.
    • Once the nuts are loose enough, use your fingers to remove the bolts easily.
  5. 2012 Nissan Sentra Rear Taillight Replacement: adım 5, 3 resimden 1. 2012 Nissan Sentra Rear Taillight Replacement: adım 5, 3 resimden 2. 2012 Nissan Sentra Rear Taillight Replacement: adım 5, 3 resimden 3.
    • Disconnect the plug by pressing a button located on the back.
    • This plug will disconnect the taillight from the car.
  6. 2012 Nissan Sentra Rear Taillight Replacement: adım 6, 3 resimden 1. 2012 Nissan Sentra Rear Taillight Replacement: adım 6, 3 resimden 2. 2012 Nissan Sentra Rear Taillight Replacement: adım 6, 3 resimden 3.
    • Loosen the sides of the taillight by gently pulling from side to side.
    • Pull the taillight straight out toward yourself in order to easily remove the wires from the small opening.
    • Grab the cord and pull the cord out through the small opening.
    • Place the damaged taillight aside.
  7. 2012 Nissan Sentra Rear Taillight Replacement: adım 7, 3 resimden 1. 2012 Nissan Sentra Rear Taillight Replacement: adım 7, 3 resimden 2. 2012 Nissan Sentra Rear Taillight Replacement: adım 7, 3 resimden 3.
    • Wipe down the vacant area and insert the new cord, from the new taillight, through the small opening.
  8. 2012 Nissan Sentra Rear Taillight Replacement: adım 8, 3 resimden 1. 2012 Nissan Sentra Rear Taillight Replacement: adım 8, 3 resimden 2. 2012 Nissan Sentra Rear Taillight Replacement: adım 8, 3 resimden 3.
    • Use your other hand to pull the wire inward and lock in the rubber grommet.
    • Make desired adjustments to the front of the taillight in order to have the best placement.
  9. 2012 Nissan Sentra Rear Taillight Replacement: adım 9, 3 resimden 1. 2012 Nissan Sentra Rear Taillight Replacement: adım 9, 3 resimden 2. 2012 Nissan Sentra Rear Taillight Replacement: adım 9, 3 resimden 3.
    • Grab the cord and connect it to the outlet.
    • This will allow the light bulbs in the new taillight to work.
  10. 2012 Nissan Sentra Rear Taillight Replacement: adım 10, 2 resimden 1. 2012 Nissan Sentra Rear Taillight Replacement: adım 10, 2 resimden 2.
    • Turn on your vehicle.
    • Put the car in reverse or step on the break to test out the new taillight.
    • If the rear lights turn on it means that the connection is intact.
    • Make sure to test both lights.
  11. 2012 Nissan Sentra Rear Taillight Replacement: adım 11, 3 resimden 1. 2012 Nissan Sentra Rear Taillight Replacement: adım 11, 3 resimden 2. 2012 Nissan Sentra Rear Taillight Replacement: adım 11, 3 resimden 3.
    • Place the small metal nuts back onto the screws and tighten them with a wrench.
    • Make sure the rubber grommet is intact so that the wires do not backflow into the taillight.
  12. 2012 Nissan Sentra Rear Taillight Replacement: adım 12, 3 resimden 1. 2012 Nissan Sentra Rear Taillight Replacement: adım 12, 3 resimden 2. 2012 Nissan Sentra Rear Taillight Replacement: adım 12, 3 resimden 3.
    • Pull the grey cover over the exposed metal and adjust it to its original place.
    • Place and push in the black plastic bolt in order to keep the grey cover from falling off.
Sonuç
This guide includes the reassembling steps so no need to backtrack!
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 34
Her zaman: 271
