Giriş
This guide will display instructions on how to change the battery in a 2013 - 2017 Ford Escape key fob. This easy to use step by step guide can help you easily repair your key fob to continue usage. The only item required for the restoration of the fob is a replacement battery. The process is brief, taking only minutes to complete.
Neye ihtiyacın var
Slide over the key release switch on the back of the fob.
To reassemble your device, replace the back cover to the key fob and secure firmly.
36 farklı kişi bu kılavuzu tamamladı.
16 Yorum
Good job. The training aid was clear and lacked nothing. Even had the battery type and a buy function which is a nice touch.
Excellent guide, Thanks for the details
Thanks for the help! Glad I just happened to have a battery and easy to follow instructions.
