Ana içeriğe geç
2013-2015 Nissan Altima Low Beam Bulb Replacement
Neye ihtiyacın var
  1. 2013-2015 Nissan Altima Low Beam Bulb Replacement, Low Beam Bulb: adım 1, 2 resimden 1. 2013-2015 Nissan Altima Low Beam Bulb Replacement, Low Beam Bulb: adım 1, 2 resimden 2.
    • Turn the steering wheel all the way to the left or right to grant access to the fender line. (Or in our case for better display, remove the wheel.)
  2. 2013-2015 Nissan Altima Low Beam Bulb Replacement: adım 2, 2 resimden 1. 2013-2015 Nissan Altima Low Beam Bulb Replacement: adım 2, 2 resimden 2.
    • Remove the fender liner using flathead screwdrivers by unscrewing all 3 locations holding fender liner to front bumper.
  3. 2013-2015 Nissan Altima Low Beam Bulb Replacement: adım 3, 3 resimden 1. 2013-2015 Nissan Altima Low Beam Bulb Replacement: adım 3, 3 resimden 2. 2013-2015 Nissan Altima Low Beam Bulb Replacement: adım 3, 3 resimden 3.
    • Now go to the underside of the fender liner and remove the three bolts using the Phillips screwdriver and flathead for the 1 clip.
    • Use same flathead screwdriver technique for the flathead highlighted in green.
  4. 2013-2015 Nissan Altima Low Beam Bulb Replacement: adım 4, 3 resimden 1. 2013-2015 Nissan Altima Low Beam Bulb Replacement: adım 4, 3 resimden 2. 2013-2015 Nissan Altima Low Beam Bulb Replacement: adım 4, 3 resimden 3.
    • Grab the small hole on the underside of the fender, and carefully pull the panel out.
    • This allows you to access the rear of the headlight housing.
  5. 2013-2015 Nissan Altima Low Beam Bulb Replacement: adım 5, 3 resimden 1. 2013-2015 Nissan Altima Low Beam Bulb Replacement: adım 5, 3 resimden 2. 2013-2015 Nissan Altima Low Beam Bulb Replacement: adım 5, 3 resimden 3.
    • Turn the lightbulb holder counter clockwise until it is released from the headlight
  6. 2013-2015 Nissan Altima Low Beam Bulb Replacement: adım 6, 2 resimden 1. 2013-2015 Nissan Altima Low Beam Bulb Replacement: adım 6, 2 resimden 2.
    • Pull up on the tab on the back of the bulb holder and simultaneously pull the light bulb out.
  7. 2013-2015 Nissan Altima Low Beam Bulb Replacement: adım 7, 3 resimden 1. 2013-2015 Nissan Altima Low Beam Bulb Replacement: adım 7, 3 resimden 2. 2013-2015 Nissan Altima Low Beam Bulb Replacement: adım 7, 3 resimden 3.
    • Replace the lightbulb by putting the new in place of the old one that was just removed.
    • Remember to insert the new light you must once again lift the tab while simultaneously inserting the new light bulb.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Rama Sura
433 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 56
Son 30 gün: 229
Her zaman: 6,020
