Ana içeriğe geç
2013 Honda Accord Headlight Replacement
Neye ihtiyacın var
  1. 2013 Honda Accord Headlight Replacement, Headlight: adım 1, 3 resimden 1. 2013 Honda Accord Headlight Replacement, Headlight: adım 1, 3 resimden 2. 2013 Honda Accord Headlight Replacement, Headlight: adım 1, 3 resimden 3.
    • Turn your vehicle off and put the emergency brake on before you begin the repair.
    • Pull the tab beside the driver side footwell to release the hood.
    • Pull the tab locking the hood upwards.
    • Pull the hood up to its maximum position.
  2. 2013 Honda Accord Headlight Replacement: adım 2, 2 resimden 1. 2013 Honda Accord Headlight Replacement: adım 2, 2 resimden 2.
    • Attach the hood strut in its designated position.
    • The headlight bulbs can be found on the left and the right of the engine bay.
  3. 2013 Honda Accord Headlight Replacement: adım 3, 2 resimden 1. 2013 Honda Accord Headlight Replacement: adım 3, 2 resimden 2.
    • The bulb is located behind the headlight and to the left of the windshield washer reservoir.
  4. 2013 Honda Accord Headlight Replacement: adım 4, 2 resimden 1. 2013 Honda Accord Headlight Replacement: adım 4, 2 resimden 2.
    • Pull the bulb out from the socket.
    • Use a prying tool at the base of the socket to detach the bulb from the holder.
  5. 2013 Honda Accord Headlight Replacement: adım 5, 3 resimden 1. 2013 Honda Accord Headlight Replacement: adım 5, 3 resimden 2. 2013 Honda Accord Headlight Replacement: adım 5, 3 resimden 3.
    • Attach the new LED bulb to the socket.
    • Don't touch the new bulb with your hands or fingers. The oil from your skin can reduce the life of the bulb or cause it to shatter.
    • Place the bulb in the holder and turn it counterclockwise.
    • Once it is firmly in place, it should not budge.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tahsin
145 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 31
Son 30 gün: 70
Her zaman: 3,447
