Ana içeriğe geç
2013 Infiniti G37 Dual Air Intakes Replacement
Neye ihtiyacın var
  1. 2013 Infiniti G37 Dual Air Intakes Replacement, Dual Air Intakes: adım 1, 3 resimden 1. 2013 Infiniti G37 Dual Air Intakes Replacement, Dual Air Intakes: adım 1, 3 resimden 2. 2013 Infiniti G37 Dual Air Intakes Replacement, Dual Air Intakes: adım 1, 3 resimden 3.
    • Pull the hood latch located inside the car under your remote holder.
    • Outside the car, find the lever under the actual hood, and squeeze and lift the hood.
    • Unscrew the mass airflow filter box from the frame with a Phillips #1 screwdriver.
  2. 2013 Infiniti G37 Dual Air Intakes Replacement: adım 2, 3 resimden 1. 2013 Infiniti G37 Dual Air Intakes Replacement: adım 2, 3 resimden 2. 2013 Infiniti G37 Dual Air Intakes Replacement: adım 2, 3 resimden 3.
    • Loosen the five bolts in the engine cover so you can have more space to access the mass airflow tubes.
  3. 2013 Infiniti G37 Dual Air Intakes Replacement: adım 3, 3 resimden 1. 2013 Infiniti G37 Dual Air Intakes Replacement: adım 3, 3 resimden 2. 2013 Infiniti G37 Dual Air Intakes Replacement: adım 3, 3 resimden 3.
    • Loosen the mass airflow sensor from the airflow tube and safely move it to a safe location out of the way.
    • Use vice grips to remove the clamp.
  4. 2013 Infiniti G37 Dual Air Intakes Replacement: adım 4, 3 resimden 1. 2013 Infiniti G37 Dual Air Intakes Replacement: adım 4, 3 resimden 2. 2013 Infiniti G37 Dual Air Intakes Replacement: adım 4, 3 resimden 3.
    • Loosen the last clamp, located at the head of the airflow tube, and give a firm tug towards you to free the entire piece.
  5. 2013 Infiniti G37 Dual Air Intakes Replacement: adım 5, 3 resimden 1. 2013 Infiniti G37 Dual Air Intakes Replacement: adım 5, 3 resimden 2. 2013 Infiniti G37 Dual Air Intakes Replacement: adım 5, 3 resimden 3.
    • Connect the mass airflow tube and tighten the clamps with a flathead screwdriver.
  6. 2013 Infiniti G37 Dual Air Intakes Replacement: adım 6, 3 resimden 1. 2013 Infiniti G37 Dual Air Intakes Replacement: adım 6, 3 resimden 2. 2013 Infiniti G37 Dual Air Intakes Replacement: adım 6, 3 resimden 3.
    • After all the clamps are tightened, place the mass airflow sensor into the tube and tighten with a Phillips #1 screwdriver.
Bitiş Çizgisi
Cordell Bowens
133 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 23
Her zaman: 879
