Ana içeriğe geç
2013 Lexus IS250 Front Dome Light Replacement
  1. 2013 Lexus IS250 Front Dome Light Replacement, Headlight Dome: adım 1, 2 resimden 1. 2013 Lexus IS250 Front Dome Light Replacement, Headlight Dome: adım 1, 2 resimden 2.
    • Open the glasses compartment located near the front dome light. This is usually a straightforward latch or button release.
  2. 2013 Lexus IS250 Front Dome Light Replacement: adım 2, 3 resimden 1. 2013 Lexus IS250 Front Dome Light Replacement: adım 2, 3 resimden 2. 2013 Lexus IS250 Front Dome Light Replacement: adım 2, 3 resimden 3.
    • Locate two housings inisde the compartment and gently pry them open using a flathead screwdriver. Take care not to damage the surrounding plastic.
  3. 2013 Lexus IS250 Front Dome Light Replacement: adım 3, 3 resimden 1. 2013 Lexus IS250 Front Dome Light Replacement: adım 3, 3 resimden 2. 2013 Lexus IS250 Front Dome Light Replacement: adım 3, 3 resimden 3.
    • Utilize a star screwdriver to remove the screws holding the front dome light in place. Ensure a steady hand to prevent any accidental dropping of screws.
  4. 2013 Lexus IS250 Front Dome Light Replacement: adım 4, 3 resimden 1. 2013 Lexus IS250 Front Dome Light Replacement: adım 4, 3 resimden 2. 2013 Lexus IS250 Front Dome Light Replacement: adım 4, 3 resimden 3.
    • With both hands wiggle both sides of the dome. Apply a bit of force at the top to release it from its position. Be cautious to not break the plastic clips securing it.
  5. 2013 Lexus IS250 Front Dome Light Replacement: adım 5, 3 resimden 1. 2013 Lexus IS250 Front Dome Light Replacement: adım 5, 3 resimden 2. 2013 Lexus IS250 Front Dome Light Replacement: adım 5, 3 resimden 3.
    • Inside, youll find two bulbs on both ends. Twist them to unlock and carefully remove.
  6. 2013 Lexus IS250 Front Dome Light Replacement: adım 6, 2 resimden 1. 2013 Lexus IS250 Front Dome Light Replacement: adım 6, 2 resimden 2.
    • Carefully remove bulb. Recommended to use gloves as it can be difficult to get a grip.
  7. 2013 Lexus IS250 Front Dome Light Replacement: adım 7, 3 resimden 1. 2013 Lexus IS250 Front Dome Light Replacement: adım 7, 3 resimden 2. 2013 Lexus IS250 Front Dome Light Replacement: adım 7, 3 resimden 3.
    • Replace these bulbs with LED alternatives, inserting them and securing by twisting.
  8. 2013 Lexus IS250 Front Dome Light Replacement: adım 8, 1 resimden 1.
    • Confirm that the bulbs are functioning by checking if the lights turn on. If not double check the alignment of the bulbs to ensure proper contact.
    • Carefully place the dome back into its original position. Ensure it aligns correctly with the plastic tips. Apply gentle pressure until it clicks back into place.
Sonuç
Christian
157 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 35
Her zaman: 161
