Ana içeriğe geç
2013 Nissan Rogue Key Fob Battery Replacement
Neye ihtiyacın var
  1. 2013 Nissan Rogue Key Fob Battery Replacement, 2013 Nissan Rogue Key Fob Battery: adım 1, 2 resimden 1. 2013 Nissan Rogue Key Fob Battery Replacement, 2013 Nissan Rogue Key Fob Battery: adım 1, 2 resimden 2.
    • Slide the small tab on the back of your fob to the left.
    • While holding the tab to the left, pull the metal key out from the top of your fob.
  2. 2013 Nissan Rogue Key Fob Battery Replacement: adım 2, 1 resimden 1.
    • Insert your opening pick into the small gap between the two halves of the fob and lightly pry until they separate.
  3. 2013 Nissan Rogue Key Fob Battery Replacement: adım 3, 3 resimden 1. 2013 Nissan Rogue Key Fob Battery Replacement: adım 3, 3 resimden 2. 2013 Nissan Rogue Key Fob Battery Replacement: adım 3, 3 resimden 3.
    • Pull the two halves of the fob apart.
    • Remove the two internal housings.
  4. 2013 Nissan Rogue Key Fob Battery Replacement: adım 4, 1 resimden 1.
    • Remove the battery.
  5. 2013 Nissan Rogue Key Fob Battery Replacement: adım 5, 3 resimden 1. 2013 Nissan Rogue Key Fob Battery Replacement: adım 5, 3 resimden 2. 2013 Nissan Rogue Key Fob Battery Replacement: adım 5, 3 resimden 3.
    • Lightly saturate a cotton swab with 70% isopropyl alcohol and wipe down the inside of the shells and the rubber pad.
    • For any small crevices dip, the toothpick into the alcohol and clean any dirt or debris.
    • Avoid wiping the circuit board and any metal components.
  6. 2013 Nissan Rogue Key Fob Battery Replacement: adım 6, 1 resimden 1.
    • Once the alcohol is dried, place a new battery into the battery housing with the proper orientation.
  7. 2013 Nissan Rogue Key Fob Battery Replacement: adım 7, 3 resimden 1. 2013 Nissan Rogue Key Fob Battery Replacement: adım 7, 3 resimden 2. 2013 Nissan Rogue Key Fob Battery Replacement: adım 7, 3 resimden 3.
    • Replace the internal components and click the two halves of the fob back together.
  8. 2013 Nissan Rogue Key Fob Battery Replacement: adım 8, 2 resimden 1. 2013 Nissan Rogue Key Fob Battery Replacement: adım 8, 2 resimden 2.
    • Slide your key back into its housing.
Sonuç
Your fob should now be fully functional!
Bir başkası bu kılavuzu tamamladı.
2 Yorum
OMG… I wish I had read this before and attempted to take my key fob apart. I’ve got it all scraped up and ugly from them telling me to use a screwdriver….never mind just do exacty everything this post tells you. I had no problems opening the key fob once I read this article .
Trust me do as this tells you step by step. Just don’t use a screwdriver as another on the www will inform you to do.
Thank you so much for posting this key fob battery replacement info.
Pamela Parker - Yanıt
Thanks worked perfectly and as stated above don't use a screwdriver I also read that but thank goodness I didn't have one
brandy france - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 18
Son 30 gün: 79
Her zaman: 4,118
