Ana içeriğe geç
2013 Subaru Impreza WRX Mud Flaps Replacement
Neye ihtiyacın var
  1. 2013 Subaru Impreza WRX Mud Flaps Replacement, Mud Flaps: adım 1, 1 resimden 1.
    • Always make sure your car is off, the parking break is applied, and you are in a safe area free from other passing cars.
  2. 2013 Subaru Impreza WRX Mud Flaps Replacement: adım 2, 1 resimden 1.
    • Turn the wheels all the way towards the side you will be working on.
    • This will create easier access to the inside of the wheel well when you are replacing the mud flap.
  3. 2013 Subaru Impreza WRX Mud Flaps Replacement: adım 3, 3 resimden 1. 2013 Subaru Impreza WRX Mud Flaps Replacement: adım 3, 3 resimden 2. 2013 Subaru Impreza WRX Mud Flaps Replacement: adım 3, 3 resimden 3.
    • Start with the front mud flaps.
    • Attach the 7/16th size socket piece to the wrench and begin removing the 7/16th diameter nuts.
  4. 2013 Subaru Impreza WRX Mud Flaps Replacement: adım 4, 3 resimden 1. 2013 Subaru Impreza WRX Mud Flaps Replacement: adım 4, 3 resimden 2. 2013 Subaru Impreza WRX Mud Flaps Replacement: adım 4, 3 resimden 3.
    • Use your Philips Head screwdriver to unscrew the farthest #6 3/4" Stainless Philips Screw.
    • Be careful not to loose the rubber gasket attached to the screw.
  5. 2013 Subaru Impreza WRX Mud Flaps Replacement: adım 5, 3 resimden 1. 2013 Subaru Impreza WRX Mud Flaps Replacement: adım 5, 3 resimden 2. 2013 Subaru Impreza WRX Mud Flaps Replacement: adım 5, 3 resimden 3.
    • Once the old mud flap is removed, grab your new mud flap and reattach it in the same manner as how you removed the old or broken one.
    • Repeat for opposite front mud flap.
  6. 2013 Subaru Impreza WRX Mud Flaps Replacement: adım 6, 3 resimden 1. 2013 Subaru Impreza WRX Mud Flaps Replacement: adım 6, 3 resimden 2. 2013 Subaru Impreza WRX Mud Flaps Replacement: adım 6, 3 resimden 3.
    • For the back two mud flaps you will need to use a slightly different technique due to the limited space you will be working in.
    • Use your hands and the 10mm wrench piece to unbolt the mud flap.
    • Once you have removed the nuts, you can move on to the #6 3/4" Philips Head Screw.
    • This step will be aided by the use of an extra small Philips screwdriver.
  7. 2013 Subaru Impreza WRX Mud Flaps Replacement: adım 7, 2 resimden 1. 2013 Subaru Impreza WRX Mud Flaps Replacement: adım 7, 2 resimden 2.
    • Replace both back mud flaps and fasten all pieces back in place.
  8. 2013 Subaru Impreza WRX Mud Flaps Replacement: adım 8, 2 resimden 1. 2013 Subaru Impreza WRX Mud Flaps Replacement: adım 8, 2 resimden 2.
    • Make sure the mud flaps are all properly tightened and positioned before driving your car again.
    • Enjoy your brand new mud flaps.
Sonuç
Alex Davis
101 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 14-3, Green Fall 2015 Cal Poly, Team 14-3, Green Fall 2015 üyesi
CPSU-GREEN-F15S14G3
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 955
