Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Turn the wheels all the way towards the side you will be working on.
Start with the front mud flaps.
Attach the 7/16th size socket piece to the wrench and begin removing the 7/16th diameter nuts.
Use your Philips Head screwdriver to unscrew the farthest #6 3/4" Stainless Philips Screw.
Be careful not to loose the rubber gasket attached to the screw.
Once the old mud flap is removed, grab your new mud flap and reattach it in the same manner as how you removed the old or broken one.
Repeat for opposite front mud flap.
Use your hands and the 10mm wrench piece to unbolt the mud flap.
Once you have removed the nuts, you can move on to the #6 3/4" Philips Head Screw.
Replace both back mud flaps and fasten all pieces back in place.
