Ana içeriğe geç
2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement
Neye ihtiyacın var
  1. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement, COMAND Centre-Dial Touchpad: adım 1, 3 resimden 1. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement, COMAND Centre-Dial Touchpad: adım 1, 3 resimden 2. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement, COMAND Centre-Dial Touchpad: adım 1, 3 resimden 3.
    • Start by pressing down on the button that opens the center arm-rest.
    • Pop each side of the silver trim using the trim removal tool or a plastic opening tool.
    • Remove the silver trim.
  2. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: adım 2, 3 resimden 1. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: adım 2, 3 resimden 2. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: adım 2, 3 resimden 3.
    • Remove the two 20 mm screws securing the center console with a T20 Torx screwdriver.
  3. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: adım 3, 2 resimden 1. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: adım 3, 2 resimden 2.
    • Make sure there aren't any loose articles in the center storage compartment.
    • Lift the end of the center-console and flip it to reveal the undercarriage of the center-dial touchpad and its wirings.
  4. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: adım 4, 3 resimden 1. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: adım 4, 3 resimden 2. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: adım 4, 3 resimden 3.
    • Press your thumb on the safety tab to remove each blue connection.
  5. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: adım 5, 3 resimden 1. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: adım 5, 3 resimden 2. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: adım 5, 3 resimden 3.
    • Press down on the center of the white connection in the middle and slide the safety latch to the left to pull out the main white connection.
  6. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: adım 6, 3 resimden 1. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: adım 6, 3 resimden 2. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: adım 6, 3 resimden 3.
    • Remove the two 15 mm T15 Torx screws holding the center-dial touchpad.
    • Firmly press the center-dial touchpad out to remove the unit.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Amin Fadhil
363 İtibar
1 Kılavuz yazıldı
Ekip
1Rehber Yorum
This is great thanks, made an account to say thank you
Nolan Scott - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 78
Son 30 gün: 380
Her zaman: 13,520
